After help ball joint nut spinning
hp006
It was going so well replacing the drive shaft. Old one out new one in. How ever there theres one ball joint that i cant get done back up. Its the drivers side rear hub nut on the right. As soon as i start to twist the nut the bolt twists too. I have managed the others by putting pressure on the joint but i cant get pressure on this as its sidewards. Any tool i have i cant seem to fit in the side as there's not the space. I have tried putting wood against it to pull it back in. All to no avail. Tried ball joint press clamps they just dont fit.
Has anyone any suggestions on how i can keep the joint in place to tighten back up.
