Guest rgvsam81 Posted August 25, 2011 Share Posted August 25, 2011 Hi guys, i have just removed my plug caps (na aero) to replace the plugs and the cavity the plug sits in is full of muck, is this normal ? how can i clean it out, i am concerned that when i remove the rear plug (where most of the dirt is) it will fall inside the cylinder, any advice would be great, ta Steve Quote Link to comment Share on other sites More sharing options...
farmer Posted August 25, 2011 Share Posted August 25, 2011 as far as the dirt in the void goes i've never been bothered with it, but have you access to to a good air line and a blow off gun ? that usually remove "dust and particles". don't remove the plugs untill its cleaned out. Quote Link to comment Share on other sites More sharing options...
Guest rgvsam81 Posted August 25, 2011 Share Posted August 25, 2011 cool , as long as its common , i will blow it all out and carry on, cheers buddy Quote Link to comment Share on other sites More sharing options...
