add heywood Posted August 25, 2011 Share Posted August 25, 2011 On my last bumper there were little sticky fixers with a piece of bendy metal stuck to them (so you could bend the metal through the mesh). Any ideas where I could get some, or how have everone else stuck their mesh to the bumper? Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 25, 2011 Share Posted August 25, 2011 (edited) I bought a length of aluminium angle strip, 25 mm x 25 mm by 1 metre long, i cut this into 25 mm lengths Drill an 8 mm diameter hole in one side and then bond the other to the inside of the bumper with tiger seal or similar. Then cable tie the mesh through the hole, i used approx 6 top and bottom, its been perfect for a few years now Heres a bit of a poor sketch to explain what i did and the end result showing you cant see the fixings + you dont damage the bumper and the mesh is easily removed Edited August 25, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 25, 2011 Share Posted August 25, 2011 http://www.hellermanntyton.co.uk/products?q=&path=WWW11CableTiesandFixings&page=3&offset=50 You can get metal ones, I thing Raceparts UK stock those. If the surfaces are not clinically clean and warm, they don't stick. I use them all the time, and the secret is cleanliness and warmth. The metal ones are slightly slimmer. They can also be neatly rivetted on. Quote Link to comment Share on other sites More sharing options...
