Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 I'm selling my spare 3UZ motor due to a couple of special engines arriving from Japan recently. It's done 15k miles and was running perfectly before I removed it from the crash damaged car. Pictures will follow shortly, the standard figures for this are 295hp and 325lb ft of torque, however I have had one of these in a boat running aftermarket efi @ 372hp/390lb ft. It comes complete with loom and all anc's, ps, alt, ac. I will include the stock ECU too, but you would be better running it with a megasquirt. I can give all info with regards to fitting this engine and assist with wiring, gearbox conversions etc. Offers around 2.2k Cheers Ben Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 Just to add, this is a 2006 engine. Link to comment Share on other sites More sharing options...
barneybrendan Posted August 25, 2011 Share Posted August 25, 2011 i take it the big boys have arrived then. Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 They have indeed! Also forgot to mention this motor is from an SC430, so its rear sump, drops straight in. There's no faffing around like with the ls400 engines. Link to comment Share on other sites More sharing options...
EMPEROR Posted August 25, 2011 Share Posted August 25, 2011 Ummm how come it's a 3UZ and 4.7l ? 2UZ is 4.7l, 3UZ should be 4.3l ? Still hell of an engine, wish I had the money!!! Good luck with the sale! Link to comment Share on other sites More sharing options...
Attero Posted August 25, 2011 Share Posted August 25, 2011 I would love to have this beast in my Supra. Ummm how come it's a 3UZ and 4.7l ? 2UZ is 4.7l, 3UZ should be 4.3l ? Still hell of an engine, wish I had the money!!! Good luck with the sale! I agree. Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 Ummm how come it's a 3UZ and 4.7l ? 2UZ is 4.7l, 3UZ should be 4.3l ? Still hell of an engine, wish I had the money!!! Good luck with the sale! Bollocks, my mistake! It's the 4.3 - ally block! Link to comment Share on other sites More sharing options...
David P Posted August 25, 2011 Share Posted August 25, 2011 http://www.celicahobby.com/forums/ubbthreads.php/topics/217105/Toyota_s_Powerful_Engines Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 http://www.celicahobby.com/forums/ubbthreads.php/topics/217105/Toyota_s_Powerful_Engines Yes David, thats the one. Link to comment Share on other sites More sharing options...
Monkpower Posted August 25, 2011 Share Posted August 25, 2011 God this engine sounds awesome. I would love to have one in my supra one day... Link to comment Share on other sites More sharing options...
SamuraiFlash Posted August 25, 2011 Share Posted August 25, 2011 Is this engine compatible with the Supra TT autobox? Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 With the 3UZ Auto bellhousing it would bolt up, however the electronics for controlling the box from the 3UZ ECU would be a nightmare! Link to comment Share on other sites More sharing options...
David P Posted August 25, 2011 Share Posted August 25, 2011 With the 3UZ Auto bellhousing it would bolt up, however the electronics for controlling the box from the 3UZ ECU would be a nightmare! Swop the T.T. valve bodies for N/A and control it with a piggy backed N/A auto ECU or Suprastick in auto or manualised mode. Simples http://www.mkivsupra.net/vbb/showthread.php?233707-Project-Supracharger&p=3080115#post3080115 Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 Swop the T.T. valve bodies for N/A and control it with a Suprastick in auto or manualised mode. Simples http://www.mkivsupra.net/vbb/showthread.php?233707-Project-Supracharger&p=3080115#post3080115 I'll leave my response as it will bolt up with a 3UZ bell housing. Can't say anymore as I've never done it. The 3UZ ECU is used to controlling a 6 speed auto. Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 Upon further investigation (and a few phone calls), I can confirm this engine will NOT work with the supra auto box NA or TT using the stock ECU. A Motec will control it, maybe the Syvecs could too. All you would need is a *UZ auto bellhousing. Link to comment Share on other sites More sharing options...
mark newman Posted August 25, 2011 Share Posted August 25, 2011 have you got all the info about fitting this engine, into a boat , ie cooling, and gearbox. Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 What kind of boat? Cooling is simple, hot out, cold in, two pipes. Transmission is somewhat more complicated Link to comment Share on other sites More sharing options...
mark newman Posted August 25, 2011 Share Posted August 25, 2011 sports boat . but you would have to have special manifolds ,for the water a exit out from the exhaust . Would like somthing like this to install into a boat, have you got pic's of the engine fitted to that boat. Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 Not to hand, boats long gone. Yeh custom pipes were made, but they didn't exit under water, just straight out the back. What type of sports boat? What inboard does it have at the moment? Link to comment Share on other sites More sharing options...
mark newman Posted August 25, 2011 Share Posted August 25, 2011 Well its a 377 MAG - 320 hp just looked . but the cost of this lump was very high. thinking of a small sports boat with a big lump in which want brake the bank. Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 I wouldn't bother swapping a 377 for the 3UZ, lots of hassle for not much gain. Link to comment Share on other sites More sharing options...
hodge Posted August 25, 2011 Share Posted August 25, 2011 I'm selling my spare 3UZ motor due to a couple of special engines arriving from Japan recently. It's done 15k miles and was running perfectly before I removed it from the crash damaged car. Pictures will follow shortly, the standard figures for this are 295hp and 325lb ft of torque, however I have one of these in a boat running aftermarket efi @ 372hp/390lb ft. It comes complete with loom and all anc's, ps, alt, ac. I will include the stock ECU too, but you would be better running it with a megasquirt. I can give all info with regards to fitting this engine and assist with wiring, gearbox conversions etc. Offers around 2.2k Cheers Ben Your 21 years old, You've had a V8 boat???? Youve built and owned Massive powered bikes???? You've had a lambigini???? You co-owned a recording Studio???? You must have told me you've had at least 3 houses since we met???? You've just bought 3 floors of the co-op buildings in newcastle for flats and a penthouse for yourself???? You get flown around the world on private jets to sort computer issues for big banks???? I am starting to think your Johnny English REBORN. Link to comment Share on other sites More sharing options...
JamieP Posted August 25, 2011 Share Posted August 25, 2011 Cooling is simple, hot out, cold in, two pipes. Sorry for the off topic, Surely you cant just suck up freezing water into a hot engine? Link to comment Share on other sites More sharing options...
Guest ugp Posted August 25, 2011 Share Posted August 25, 2011 Surely you cant just suck up freezing water into a hot engine? I was referring to the in & out to a radiator Jamie. Link to comment Share on other sites More sharing options...
mark newman Posted August 25, 2011 Share Posted August 25, 2011 radiator in a boat.? Link to comment Share on other sites More sharing options...
