sdistc Posted August 24, 2011 Share Posted August 24, 2011 Do you know what that tool is called? I can't find anything Look for a "cable tie tensioner". There are quite a few different designs, but it's essentially the same tool as is used to tie the stainless straps to pallets - so most industrial places will use them. Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted August 24, 2011 Share Posted August 24, 2011 (edited) Late as usual I bought these... http://www.ebay.co.uk/itm/180643596450?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 Doesn't mention any tooling to fit them? lol what a bargain price.. i payed 10 times that for mine an the problem i had with mine. there is a little stealball inside the tieclamp and when you tighten they tend to back off just a millimeter or fractions of a millimeter and then they aren't verry tight anymore. ill see if i can find what i used. and its a lot easier to get a tight fitting with since you just take a plier and turn. somthing like this just abit thicker http://www.ebay.co.uk/itm/20m-Stainless-Steel-316L-wire-HHO-fuel-saver-Water4Gas-/110455866502?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19b7aec486 Edited August 24, 2011 by Hellstrom (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2011 Author Share Posted August 24, 2011 lol what a bargain price.. i payed 10 times that for mine an the problem i had with mine. there is a little stealball inside the tieclamp and when you tighten they tend to back off just a millimeter or fractions of a millimeter and then they aren't verry tight anymore. ill see if i can find what i used. and its a lot easier to get a tight fitting with since you just take a plier and turn. somthing like this just abit thicker http://www.ebay.co.uk/itm/20m-Stainless-Steel-316L-wire-HHO-fuel-saver-Water4Gas-/110455866502?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19b7aec486 Yeah that's what we use in work. I'll see if I can 'borrow' some Quote Link to comment Share on other sites More sharing options...
