sweetcal66 Posted August 24, 2011 Share Posted August 24, 2011 Basically woke up the other morning and went unlock car and nothing opend the door with key went to turn it over nothing jumped the car and started. let it run for about 45 mins to an hour took it on drive etc, and this morning same thing unlocked this time but not enough power to start the engine?? So is my battery knackerd?? Please help also if it is if anyone in north east has a battery for supra will buy today. Cheers Callum Link to comment Share on other sites More sharing options...
stevie_b Posted August 24, 2011 Share Posted August 24, 2011 It sounds like it could be flat (this is different to goosed). Has the car been standing a few days without being driven? A mulitmeter will confirm whether it's flat or not. A trickle charger might bring a flat battery back from the dead, but the condition of the battery will dictate whether its new life will be short-lived or not. You might want to check that the cables are attached to the battery posts properly. One of the most competitive places to buy a battery is a Toyota dealership, surprisingly. There's a good thread (sticky?) on here about batteries. One of the least competitive in my experience is Halfrauds. Link to comment Share on other sites More sharing options...
sweetcal66 Posted August 24, 2011 Author Share Posted August 24, 2011 yeah car was stood a few days with out start, but did start fine after that then the day after wudnt start battery was flat it jumped over and started, then today fob/alarm unlocked doors but not enough power to start engine i have it jumped over at the minute but if i turn it off again will it do the same thing?? Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2011 Share Posted August 24, 2011 You need to take it for a proper run to get it out of the low charge zone. It is most likely fubarred though. Link to comment Share on other sites More sharing options...
sweetcal66 Posted August 24, 2011 Author Share Posted August 24, 2011 any idea how long drive should be until battery should have charge back in it? cheers Link to comment Share on other sites More sharing options...
Guest stevie.84 Posted August 24, 2011 Share Posted August 24, 2011 What might be an idea bud is if there's little screws on the top you can open them and check the fluid inside, if low try buying some deionised water and refil, that sorted my old laguna battery out a few year ago. Link to comment Share on other sites More sharing options...
sweetcal66 Posted August 24, 2011 Author Share Posted August 24, 2011 ok cheers for help will try it all out thanks callum Link to comment Share on other sites More sharing options...
SupraP-Z Posted August 24, 2011 Share Posted August 24, 2011 Check it with a multimeter/Voltmeter, or just pop it out and put it on a trickle charger for the day. Done it loads of times when the car has just been sitting, works great Link to comment Share on other sites More sharing options...
TT Paul Posted August 24, 2011 Share Posted August 24, 2011 if its charging ok (14v) but keeps going flat get a new battery, it happend to me on way to pod, halfrauds £95 no choice needed it at least if your at home you can shop around Link to comment Share on other sites More sharing options...
SteveC Posted August 24, 2011 Share Posted August 24, 2011 When a car battery has been discharged to the point when there's not enough power to unlock the door, then they usually don't recover to anything like their original capacity; car batteries don't take kindly to being fully flattened. Three or four days continuous charge with a trickle charger may improve things a little, but you'll be very lucky if it gets to 50% of the capacity of a new battery. Link to comment Share on other sites More sharing options...
sweetcal66 Posted August 25, 2011 Author Share Posted August 25, 2011 seems to be ok this morning woke up got in and went to work no problem, but still will check see if it is dried out if so will top up see how that goes, but will end up getting a new battery near future. Cheers for help people Callum Link to comment Share on other sites More sharing options...
