Monster supra Posted August 23, 2011 Share Posted August 23, 2011 Hello all I have a 94 jap auto supra First problem is the radiator overflow tank is making gurgling noises & sometimes brown colour water weeps from the black hose on the tank. Second problem is power steering makes a whirring noise when i turn the steering wheel, could this be due to low fluids (not checked yet) Third problem is the smell of petrol fumes from the air filter Final problem I have a big stereo install done by a authorised dealer. Done a few years back when someone else owned the car. It has a split relay under the bonnet , optima yellow top in the boot & I had a new battery fitted in the front about a month ago. when driving with the stereo on the car wants to stall when i stop , could this be due to not enough charge to engine battery , Should i upgrade alternator or could the split relay not be working right or could this be some other issue All help would be gratefull Link to comment Share on other sites More sharing options...
mellonman Posted August 23, 2011 Share Posted August 23, 2011 first radiator over flow noise is normal its where the water is no longer cooled by air flow and water expands, its brown because of radiator water can be rusty ( or pinky coolet is used), fush through the cooling system if the coolet is a couple of years old. power steering normally makes that noise and even more so on full lock, petrol from air filter, is it a cleanable filter as they might of used petrol to clean it. Link to comment Share on other sites More sharing options...
evinX Posted August 23, 2011 Share Posted August 23, 2011 My supra used to make the power steering noise when i first got it, becuase she wasnt driven for a while, after a while it went away. I used to get petrol smells to, still do on hot days, could be running rich and need new 02 sensors? i need to do this Smell of petrol from the air filter? you sure?! get a new filter from toyota, cost me around £15-25 ish, then take it from there. I hear of this problem so many times on all sorts of cars, yes a more powerful altenator should be able to handle it as it cant recharge the batterys quick enough due to the demand Changed my antifreeze yesterday, if you look at the rad from above, at the bottom right theres a plastic plug to drain it, put some new stuff in last year and yesterday it was all brown and rusty. Got some pre mixed red antifreeze from toyota for £20 + vat. You have to fill up the overflow tank to, so id remove and drain that crap out of there to. Link to comment Share on other sites More sharing options...
Monster supra Posted August 23, 2011 Author Share Posted August 23, 2011 Will flush the water system tomorrow The power steering is louder then normal not too sure if its a cleanable filter , Think i will by a new one & see if that solves it. Thank you mellowman for the advice. Link to comment Share on other sites More sharing options...
imi Posted August 23, 2011 Share Posted August 23, 2011 Monster supra said: Second problem is power steering makes a whirring noise when i turn the steering wheel, could this be due to low fluids (not checked yet) Could be air in the power steering, check the pipes for splits, check if there are bubbles in the reservoir when turning the steering, could also be gunk in the power steering reservoir - this can either be cleaned or replaced. Link to comment Share on other sites More sharing options...
Monster supra Posted August 23, 2011 Author Share Posted August 23, 2011 There is a general smell of petrol Last week i took the air filter off the car & it was a strong smell of petrol on it Today while driving home i could smell petrol in the car ( not liking that ) i didnt have the heaters on either , i turned them on to see if the fumes where in the heating system but its not. Link to comment Share on other sites More sharing options...
imi Posted August 23, 2011 Share Posted August 23, 2011 You will need to post some pics of your engine bay and a spec of your car; for all we know it could be a bogged single conversion with 8 injectors.... Link to comment Share on other sites More sharing options...
Monster supra Posted August 23, 2011 Author Share Posted August 23, 2011 will get some pics up tomorrow Link to comment Share on other sites More sharing options...
Monster supra Posted August 23, 2011 Author Share Posted August 23, 2011 I got a couple of pics Model is E-JZA80 Engine code 2JZ-GE 1994 Auto Yes it has NOS but i have not used it yet ! Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 23, 2011 Share Posted August 23, 2011 Could be a cracked radiator header tank, quite common. You need to get a fan shroud for the rad fan, it's missing off yours. Link to comment Share on other sites More sharing options...
Monster supra Posted August 25, 2011 Author Share Posted August 25, 2011 Power stering issue fixed , Low on fluids. The problem with the smell of petrol is worrying me Had the bonnet open today with the engine running & can see a lot of petrol dripping of the air filter !! This cant be right Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 25, 2011 Share Posted August 25, 2011 It is definitely not right. but how fuel can get from the injectors through the manifolding, and throttle body, back to the air filter, I don't know. Well, it can't. Does it seem to run OK? Link to comment Share on other sites More sharing options...
Andy Blyth Posted August 25, 2011 Share Posted August 25, 2011 I would suggest that the fuel is coming from the nitrous / fuel nozzle on your air intake pipe just before the throttle. Take the nozzle out to check. You could have a leaky solenoid valve or have a wiring issue. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 26, 2011 Share Posted August 26, 2011 Andy sounds spot on, I have to say I hadn't seen that. It must be coming from elsewhere than the main injectors. Needs fixing, sounds a real fire hazard. Link to comment Share on other sites More sharing options...
dude Posted August 26, 2011 Share Posted August 26, 2011 It will be hard to pinpoint where the fuel system is coming from, I would say the charcoal filter is a good statring point, the PAS is prob a blocked filter in the reservoir. Link to comment Share on other sites More sharing options...
Monster supra Posted August 27, 2011 Author Share Posted August 27, 2011 I think the fuel problem is from the nitros Im gonna disconnect it & see how it goes. Car has developed a new problem Leaky head gasket ! Which i think is why i have some problems. Are these easy to change ? Is there a guide here for the torque setting for the head bolds ? Link to comment Share on other sites More sharing options...
Monster supra Posted August 29, 2011 Author Share Posted August 29, 2011 Could anyone help with the torque settings on the head bolts please. Link to comment Share on other sites More sharing options...
dude Posted August 29, 2011 Share Posted August 29, 2011 Dude if the head bolts arent tight its normally because the car has got really hot, hot enought the head would now be junk Link to comment Share on other sites More sharing options...
Monster supra Posted August 29, 2011 Author Share Posted August 29, 2011 Gonna be replacing the head gasket & need to know what order to tighten the bolts in & to what torque settings. Link to comment Share on other sites More sharing options...
dude Posted August 29, 2011 Share Posted August 29, 2011 OK but you need to check the straightness of the head or more precise the cam bearings. Link to comment Share on other sites More sharing options...
