Steering Wheel Play
Geo
Does a Vitara have a rack or steering box ? if its a box then my monies on the idler
arm having play in it.
Or the box needs adjusting which is usually a lock nut with a screw which you wind
in to take the play out of the worm gear.
If it is that only adjust by a very small amount (less than 1/8 th of a turn) at a time as
you can make the steering very heavy if overdone.
think its the steering gear guys, i've had the car jacked up, and all rod tie ends have no play etc, the rack goes into the little steering gear box, so going to see if i can adjust it after dinner. :D
cheers for the helps guys :thumbs:
