StuartW Posted August 22, 2011 Share Posted August 22, 2011 Hi I have this now surplus to requirements as I have now upgraded to a Syvecs All singing all dancing S8 (F1 and Touring car spec) ECU so it can control the NOS too. it does not require any NOS relays to activate any solenoids as they are solid state and already built in to the unit, we found by using this over a fixed shot system it saved us NOS and gave us performance gains. http://www.noswizard.com/index.php/max-extreme-nitrous-controller-race-619.html?SID=0i647qnl7asgor76covlduklg6 The unit has a lot of brilliant features and is 4 months old, i have used it at 6 events this year and it performed well with no faults. Trevor the "Wizard of nos" who owns the company and designed the unit is always available for support and set up help. there is a dedicated forum especially for this unit and all the instructions/features can be seen on the wizards of nos UK website. I originally went for this unit and WON systems as they are UK based and keep parts in stock on the shelf, also Trevor Has proved himself in his 30 years of NOS experience to have had some Innovative idea's that have an emphasis on safety and performance. this is what they say; The Max Extreme – the most advanced nitrous control unit in the world. A Max Extreme is the most essential addition you could make to your fixed hit nitrous system, to further improve your vehicles performance and reliability. The Max Extreme (race) is by far the most advanced fully featured nitrous controller in the world, benefiting from the most innovative software features, to deliver superior, control, performance and safety over any other controller currently available. Control and adjustability are the keys to optimum nitrous performance and Max offers extreme levels of both. Every tenth of a second of nitrous use can be effectively programmed and tailored to each specific gear, even if you drive an automatic. In addition to the control and adjustability the Max offers extreme levels of safety in a number of features unique to WON. Whatever performance improvements you’ve already achieved with your fixed hit system, you will improve that by a substantial margin by adding a Max Extreme, plus you’ll benefit from the added levels of safety it provides. On the performance front key features the Max offers are; · FIVE individually adjustable and independent power points per gear x 6 gears · Adjustable and independent build time per gear · Adjustable RPM linked activation and de-activation points On the safety front key features the Max offers are; · Adjustable nitrous ONLY delay to prevent a lean hit back fire · RPM window switch to prevent accidental system activation leading to back fires · Fuel pressure window switch to prevent lean running if fuel pressure fell · Nitrous pressure window switch to prevent lean running due to excessive nitrous pressure. For a unit that offers such a huge range of features it is exceptionally easy to use (especially for the Pro-racers with gloved hands), with its; · Large tactile push buttons · Large bright LCD screen · Clear bright text · Easy to follow software · Totally live mapping Totally adjustable without the need of laptop or a PDA (and the associated complexity and expense that causes), to make even the simplest adjustments. To top it all off, the Max Extreme even logs the most important data such as fuel pressure, battery voltage, RPM etc. The MAX Extreme is fully software upgradeable, which means its future protected *PLEASE NOTE - Some Max Extreme features require additional components not supplied with the base unit. Dimensions - H 85mm x W 175mm x D 32mm Full Feature List Max Extreme User & Installation Manual "ALL PRICES ARE SUBJECT TO VAT INSIDE THE EU ZONE" New price inc vat is £586.80 i will take £450 for the unit as need some new slicks for the beast... Reduced to £400... Link to comment Share on other sites More sharing options...
StuartW Posted August 23, 2011 Author Share Posted August 23, 2011 ^^ Bump as it was proper late when i posted this up! ^^ Link to comment Share on other sites More sharing options...
StuartW Posted September 3, 2011 Author Share Posted September 3, 2011 weekend bump Link to comment Share on other sites More sharing options...
StuartW Posted September 6, 2011 Author Share Posted September 6, 2011 Reduced to £400 for quick sale! Link to comment Share on other sites More sharing options...
StuartW Posted September 13, 2011 Author Share Posted September 13, 2011 still available Link to comment Share on other sites More sharing options...
Marco79 Posted September 15, 2011 Share Posted September 15, 2011 I have one of these they are an amazing bit of kit!!! Link to comment Share on other sites More sharing options...
StuartW Posted September 22, 2011 Author Share Posted September 22, 2011 last bump before i PX it with the supplier for a 6 port system..The good thing about Wizards stuff is it always has a px value on upgrading. they are very good like that ;-) Link to comment Share on other sites More sharing options...
