Paul Posted August 22, 2011 Share Posted August 22, 2011 Couple of questions, looking to replace my vacuum hoses, currently got blue silicone ones on but want to go back to a more stock look. Never had a problem with the silicon hoses but I guess OEM would be best, any idea of the sort of cost for replacing all the vac hoses, is there a kit or are they individual part numbers? Also want something a little better than cable ties to secure them, I've used twin ear 'O' clips before but would the single ear ones be OK as I can hide the crimped part on the underside of the hose? Looking at this sort of thing: http://www.ebay.co.uk/itm/Hose-O-Clips-Stainless-7-8-2mm-O-D-pack-4-/160453661388?pt=UK_Air_Tools_and_Compressors&hash=item255bc892cc Quote Link to comment Share on other sites More sharing options...
jimwire Posted August 22, 2011 Share Posted August 22, 2011 I'm also interested in doing this but want to get the correct hoses. Subscribed. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 22, 2011 Share Posted August 22, 2011 Not sure theres a kit as such. Just source a supplier of good quality rubber hose in the correct diameters, cut to the correct sizes, et voila Quote Link to comment Share on other sites More sharing options...
Paul Posted August 22, 2011 Author Share Posted August 22, 2011 Not sure theres a kit as such. Just source a supplier of good quality rubber hose in the correct diameters, cut to the correct sizes, et voila Aren't the OEM ones shaped and 2 or 3 ply? Toyota must sell them still, would be a case of getting a list of part numbers though. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 22, 2011 Share Posted August 22, 2011 (edited) Speak to the specialist hose suppliers, they all do vac hose along with normal silicon hose in matching colours. Just buy a length of the correct internal diameter hose and cut it yourself to the required length with a stanley blade, etc When doing this do one hose at a time http://www.merlinmotorsport.co.uk - Samco http://www.viperperformance.co.uk - own make http://www.sfsperformance.co.uk - own make Edited August 22, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 22, 2011 Share Posted August 22, 2011 Aren't the OEM ones shaped and 2 or 3 ply? Toyota must sell them still, would be a case of getting a list of part numbers though. Of course you could do that But sure it would be more cost effective to get a length or couple of lengths different diameters of hose. Quote Link to comment Share on other sites More sharing options...
Paul Posted August 22, 2011 Author Share Posted August 22, 2011 Of course you could do that But sure it would be more cost effective to get a length or couple of lengths different diameters of hose. Most of the smaller diameter silicone hoses tend to be silicone only with no reinforcement, not got a problem with this but if there are better alternatives then that's what this thread is about. edit: anyone got any thoughts on the 'O' clips? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 22, 2011 Share Posted August 22, 2011 Most of the smaller diameter silicone hoses tend to be silicone only with no reinforcement, not got a problem with this but if there are better alternatives then that's what this thread is about. edit: anyone got any thoughts on the 'O' clips? Thats why I said quality rubber hose Those clips are whats fitted to the hoses on my Skoda Tdi, guess theyre OE fitment to a lot of cars. Heres a grab of the vac system and part numbers if youre interested. Best I can do sadly Quote Link to comment Share on other sites More sharing options...
Paul Posted August 22, 2011 Author Share Posted August 22, 2011 Thats why I said quality rubber hose Those clips are whats fitted to the hoses on my Skoda Tdi, guess theyre OE fitment to a lot of cars. Heres a grab of the vac system and part numbers if youre interested. Best I can do sadly [ATTACH=CONFIG]137674[/ATTACH] Cheers Looks a pita to get the Toyota ones, so it's a case of sourcing the right dia. rubber hoses then in lengths. Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted August 23, 2011 Share Posted August 23, 2011 I bought all my hose from my local motor factors. Swapped them all on by on...sorted. There are 2 or 3 that you'll need to get from Mr T though as the bends are too tight and they kink! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 23, 2011 Share Posted August 23, 2011 Gates and Wurth supply good hose in the right materials, with the right ID's. You need to buy a small reel though, I don't think either will chop one up. Quote Link to comment Share on other sites More sharing options...
Paul Posted August 23, 2011 Author Share Posted August 23, 2011 Gates and Wurth supply good hose in the right materials, with the right ID's. Oooh, any online suppliers that you know of ? What am I looking for, 2 ply hose? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 23, 2011 Share Posted August 23, 2011 Wurth have reps in vans. Gates may have an online supply, not sure. Most good auto factors have hose on reels, have a ring around. Quote Link to comment Share on other sites More sharing options...
Paul Posted August 23, 2011 Author Share Posted August 23, 2011 Wurth have reps in vans. Gates may have an online supply, not sure. Most good auto factors have hose on reels, have a ring around. OK, cheers mate, I've got a good independent motor factor down the road so will pop in and see what they have. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 23, 2011 Share Posted August 23, 2011 Just for you : http://www.wurth.co.uk/cat.php?page=23&search=§ion=06 Quote Link to comment Share on other sites More sharing options...
Paul Posted August 23, 2011 Author Share Posted August 23, 2011 Nice one, and they do dedicated vacuum hoses too ! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 23, 2011 Share Posted August 23, 2011 That's the stuff I tend to use, great quality. Well, it's German! Quote Link to comment Share on other sites More sharing options...
Paul Posted August 23, 2011 Author Share Posted August 23, 2011 Well, it's German! Don't mention the war............http://www.youtube.com/watch?v=JobArfqq1Ug&feature=related Quote Link to comment Share on other sites More sharing options...
