Heyrick Posted August 22, 2011 Share Posted August 22, 2011 (edited) Hi all, As per this thread... http://www.mkivsupra.net/vbb/showthread.php?253010-Unexpected-find-Mines-ECU ... I found I had a Mines ECU fitted. I sent to Mines to ask about the spec and received the following: >>Dear Mr. White, The basic specs of the ecu is Fuel mapping has been optimized Injection and ignition timing adjusted Speed limiter has been cut Rev limiter has been raised 500 rpms Designed to run on 100 RON(at the least 98 RON) rating octane gasoline Boost set on the ecu at 1.0kg (set at a safe level. Possible to boost higher depending on the circumstances, but boost at your own risk.) Best Regards, Daniel Larson Mine's Co., Ltd. Questions: 1. I am guessing 1.0kg = 1bar? Can someone confirm? 2. Will it fuel cut over 1.0kg boost? not sure what he meant by "depending on the circumstances"? I'm stock Jspec TT apart from 2nd decat at the moment but hoping to go for a modest BPU soon. Thanks for your help! Edited August 22, 2011 by Heyrick (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted August 22, 2011 Share Posted August 22, 2011 Hi all, As per this thread... http://www.mkivsupra.net/vbb/showthread.php?253010-Unexpected-find-Mines-ECU ... I found I had a Mines ECU fitted. I sent to Mines to ask about the spec and received the following: >>Dear Mr. White, The basic specs of the ecu is Fuel mapping has been optimized Injection and ignition timing adjusted Speed limiter has been cut Rev limiter has been raised 500 rpms Designed to run on 100 RON(at the least 98 RON) rating octane gasoline Boost set on the ecu at 1.0kg (set at a safe level. Possible to boost higher depending on the circumstances, but boost at your own risk.) Best Regards, Daniel Larson Mine's Co., Ltd. Questions: 1. I am guessing 1.0kg = 1bar? Can someone confirm? 2. Will it fuel cut over 1.0kg boost? not sure what he meant by "depending on the circumstances"? Thanks for your help! 1kg = 1bar yes It won't fuel cut over 1 bar, what they mean is that you can increase the boost to a higher level if you choose but it's at your own risk. Quote Link to comment Share on other sites More sharing options...
