95supra Posted August 22, 2011 Share Posted August 22, 2011 (edited) Would be great if you could could read and help me out! thanks in advance. Ok so here is the deal. I bought my Supra a few weeks ago. Whenenver I hit 0.5 bar my car stuttered a lot and shaked... basically it was misfiring. So I changed the coil packs and spark plugs, the problem was gone. The car is still very sluggish though. Sometimes I will try to excelerate and my RPM will jump from like 3000 to 4000-6000 and the car just won't go. Also today why I was driving on the highway this happened a few times but the car randomly started shaking. It sounded like it was choking and when I stepped on the gas it had no response at all. It was just BUB BUB BUB BUB for 5-10 secs and it went away. My performance upgrades are as follows: greddy twin intake blitz nur spec r catback exhaust mishimoto radiator thick blitz intercooler with 3" poping vent to atmosphere wastegate etc.. no boost controller or not piggybacks, but have boost gauge, oil temp, engine pressue I think as well (total of 3). so I have an exhaust with full stock cat. From the description I give does it sound like I need to upgrade my fuel pump or what exactly is happening? is my boost spiking or am I hitting fuel cut? the car drives much better with the new coils and plugs but I want it performing as it should! I would like to get a downpipe but I don't want to till I get this problem solved. this is a 1995 jdm tt6. Edited August 22, 2011 by 95supra (see edit history) Quote Link to comment Share on other sites More sharing options...
GINNO78 Posted August 22, 2011 Share Posted August 22, 2011 Doesnt sound like fuel pump sounds more like blocked CAT car is being strangled .....revs rising but car not going anywhere also sounds like a knackered clutch?...just a few possibles for you to check Quote Link to comment Share on other sites More sharing options...
95supra Posted August 22, 2011 Author Share Posted August 22, 2011 I have a twin disc clutch masters clutch setup. When I release the clutch it looks like the clutch does all the work. It will be engaged but the starts are always very very slow and shitty. I can't even gun it because the clutch is still hooking on. I know a good mechanic and he told me it could be the release throw out bearing or something... he has heard a lot of twin disc lutches and this one was different or something. Quote Link to comment Share on other sites More sharing options...
TUNERAIDER Posted August 22, 2011 Share Posted August 22, 2011 I had the same thing stuttering especially from second gear.Loss of power when pulling away but fine when in third and above. It was my HT leads that caused the problem replaced them and all was fine. Quote Link to comment Share on other sites More sharing options...
95supra Posted August 22, 2011 Author Share Posted August 22, 2011 I had the same thing stuttering especially from second gear.Loss of power when pulling away but fine when in third and above. It was my HT leads that caused the problem replaced them and all was fine. HT leads? what exactly is that Quote Link to comment Share on other sites More sharing options...
Scott Posted August 22, 2011 Share Posted August 22, 2011 HT leads? what exactly is that N/A only. Quote Link to comment Share on other sites More sharing options...
David P Posted August 22, 2011 Share Posted August 22, 2011 Fuel filter maybe. Quote Link to comment Share on other sites More sharing options...
dude Posted August 22, 2011 Share Posted August 22, 2011 You need to very carefully check all your connections, both vacuum and electrical, check for hard vacuum hoses and check connection to map sensor etc, there is also a little one way canister in the inlet manifold this can go bad. Quote Link to comment Share on other sites More sharing options...
Nic Posted August 22, 2011 Share Posted August 22, 2011 HT leads? what exactly is that They are the wires between the distributor and the plugs, only the 2J-GE/NA has HT leads. Sometimes I will try to excelerate and my RPM will jump from like 3000 to 4000-6000 and the car just won't go. From your description it sounds like the clutch is slipping ie. the engine is revving but you aren't getting forward drive. To test try accelerating from 30mph in 4th gear, this will put more load on the clutch, if it is slipping you will see/hear the engine revs rise but will get little/no forward drive. Only try this once as a slipping clutch generates a lot of heat. Quote Link to comment Share on other sites More sharing options...
95supra Posted August 23, 2011 Author Share Posted August 23, 2011 (edited) You know what.................. I think my clutch is fuked. I was rolling in traffic, I forgot what gear I was in this vid (either 4 or 5). I will try accelerating but my engine will rev up and I JUST WONT GO!!!!! it happens in most gears. When the clutch is cold for the first 15 minutes of driving it is rather smooth. For longer periods its horrible. Also when starting in grears 1 and 2 it grabs very very slow. I can't even keep up with traffic till I get into a higher gear. Sometimes when I am not in gear or engaging the clutch there will be some chatter as well... I'm hoping my clutch is fine just maybe something smaller. here is a vid, this is what a slipping clutch looks like? and no I was not revving this is my simply stepping on the gas trying to get the car to go. [video=youtube;AEar4-no2hg]http://www.youtube.com/watch?v=AEar4-no2hg BTW, this was origianlly a n/a 5-spd. Converted to 2JZ-GTE V160 6-speed. Has n/a differential so the speedo is a bit off. I was going about 60 km or so not 30 lol Edited August 23, 2011 by 95supra (see edit history) Quote Link to comment Share on other sites More sharing options...
GINNO78 Posted August 23, 2011 Share Posted August 23, 2011 Yep thats clutch mate Quote Link to comment Share on other sites More sharing options...
Nic Posted August 23, 2011 Share Posted August 23, 2011 The clutch is definitely slipping, don't drive with it like that, a slipping clutch generates a lot of heat which can damage the flywheel. Quote Link to comment Share on other sites More sharing options...
