Rear Fog light PCB...
heckler
Hi mate, got my second one in the post today cheers mate
Just a question as I'm confused
I've now got led rears and looking at how my fog light was connected to my previous lights it was wired into the loom only and not power and switch
So what would be the way to connect these to my lights?
Cheers
  • Replies 123
Cheers
what do you mean tied into the loom? got any pictures?
Right just been out and took it apart and took some pics as you can see i have LED lights and a crappy cut in fog light
There is only 2 wires coming from the fog light and were wired into the bulb as picture
so i have no clue how this works or how to do the new mod with the PCB's
The LED lights
The fog light
The wires from the fog light
The whole bulb loom
and the wires where the fog was cut in
Solid green wire and a white with black stripe wire were used
Your help will be muchly appreciated
Yeah I will be getting rid of it
I have a switch and it worked perfectly fine before I changed the rear lights and disconnected the fog
I was just confused as I assumed the switch would be connected to the fog light
Cheers for that link will have a play tomorrow
Also I have another problem
My indicators flash stupidly fast
Do you know how I can fix this??
Cheers again
All down to the current draw of LED's - much less than a normal bulb. Two ways to cure this, put a load across the indicator to simulate a bulb (I use a 50w 10ohm resistor on my rear lights ) or you can change the flasher relay for one that is capable of driving LED lights.
  • 4 months later...
  • 3 weeks later...
