Stock suspension removal problem
pjavon
I'm in the middle of re-moving my stock (black) suspension but for the life of me I can't seem to get the actual coilover out of the front.
I've read this thread and it doesn't seem to be a major problem, although these are different shocks so could be shorter. I was hoping I wouldn't need to remove the wishbone but i'm running out of idea's. Spring clamps will only close the spring up so aren't helping as the gas shocks are hard to pull down and close up as well.
I've removed all the bolts and the anti rollbar strut but can't maneuver the spring out through the top wishbone.
Any help really appreciated
Just take out the long bolt( holds the wishbone to the alloy subframe), on the passenger side you`ll need to lower the washer fluid bottle to, so the bolt has somewhere to go, i normally put the bolts in from the other side on refitting then next time its easy.
You a really big bar to pull the suspension right down so get yourself an extra body.
The easier/alternative way is indeed removing the top wishbone which isn't hard at all. In fact it makes it much easier IMO.
Thanks guy's, took the top wish bone bolt out,sorted:D
