dubz Posted August 20, 2011 Share Posted August 20, 2011 hi does any one no if its possible to use a nissan skyline engine in a supra, and use everything else appart from the engine wirring loom and ecu Link to comment Share on other sites More sharing options...
bignum Posted August 20, 2011 Share Posted August 20, 2011 (edited) Pretty sure top secret in japan did this, it`d be alot of work i think as the exhaust/ inlet is on the opposite side of the engine compared to a 2jz, also not sure there would be any benefits, maybe less reliable. Edited August 20, 2011 by bignum (see edit history) Link to comment Share on other sites More sharing options...
AlexM Posted August 20, 2011 Share Posted August 20, 2011 I've seen one on youtube, no idea what it'd take or why you'd do it though! Link to comment Share on other sites More sharing options...
Swampy442 Posted August 20, 2011 Share Posted August 20, 2011 With enough money and time you can fit anything to anything. Question is why bother? Link to comment Share on other sites More sharing options...
Bailey. Posted August 20, 2011 Share Posted August 20, 2011 I wouldn't trade a 2jz for a rb engine any day of the week, so as above, what's the full story behind the question? Link to comment Share on other sites More sharing options...
letmeshowyou Posted August 20, 2011 Share Posted August 20, 2011 Same as everyone else ahas said. You could, it's been done, but really what's the point? (unless of course you go the whole way and transplant the 4WD system too!) Link to comment Share on other sites More sharing options...
tkddav3 Posted August 20, 2011 Share Posted August 20, 2011 yeah top secret did one in thier white supra. id still say stick with the 2jz thoughhhhh Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 20, 2011 Share Posted August 20, 2011 Conversions are never impossible but the 2JZ engine is better than the RB26 engine .. Link to comment Share on other sites More sharing options...
Ricky49 Posted August 20, 2011 Share Posted August 20, 2011 I would never take a skyline engine over a 2jz gte. I would like to put one in the wifes qashqai though Link to comment Share on other sites More sharing options...
dubz Posted August 20, 2011 Author Share Posted August 20, 2011 thanks for the replys the reason why i asked is because i could get the engine cheaper than a 2jzgt engine but i guess il jst stick to the supra engine Link to comment Share on other sites More sharing options...
Kirk Posted August 20, 2011 Share Posted August 20, 2011 Even the 1JZ is a better engine than the RB26 IMO. There a lot cheaper than a 2JZ. Link to comment Share on other sites More sharing options...
dubz Posted August 20, 2011 Author Share Posted August 20, 2011 i dnt meen to be a pain but i was looking at the 1jz engines and they much cheaper to buy but when it comes to fitting one is it as simple as fitting a 2jz engineEven the 1JZ is a better engine than the RB26 IMO. There a lot cheaper than a 2JZ. Link to comment Share on other sites More sharing options...
Swampy442 Posted August 20, 2011 Share Posted August 20, 2011 Hang on, you wanted to put the RB in instead of the JZ GTE because it was cheaper? I had to read that twice to make sure I wasnt seeing things Link to comment Share on other sites More sharing options...
Kirk Posted August 20, 2011 Share Posted August 20, 2011 i dnt meen to be a pain but i was looking at the 1jz engines and they much cheaper to buy but when it comes to fitting one is it as simple as fitting a 2jz engine Its not difficult if your handy with electrics as you will need to do some wiring to the 1JZ engine loom to make it run and work with the rest of the original loom. You may need to change the sump as well but that's not a hard task. Link to comment Share on other sites More sharing options...
Scott Posted August 20, 2011 Share Posted August 20, 2011 Hang on, you wanted to put the RB in instead of the JZ GTE because it was cheaper? I had to read that twice to make sure I wasnt seeing things The ebay belt kits are also cheaper though. Long term savings. These things just crowbar in and work anyway. Couple of decent fixings and it'll be good to go. Link to comment Share on other sites More sharing options...
rob wild Posted August 21, 2011 Share Posted August 21, 2011 They're both good engines in there own right, I would say that the 2JZ is a new design and has a heavier and stiffer crank and block. Although from a driving point of view I do enjoy the high revving ability of my RB. Just IMO Link to comment Share on other sites More sharing options...
j_jza80 Posted August 21, 2011 Share Posted August 21, 2011 They're quite different in their character. I'd say the RB is a nicer sounding engine (just) but nowhere near as tough and MUCH more expensive to tune for big power. Ie, tuning an RB for a reliable 600hp requires a lot more work. Link to comment Share on other sites More sharing options...
j_jza80 Posted August 21, 2011 Share Posted August 21, 2011 They're both good engines in there own right, I would say that the 2JZ is a new design and has a heavier and stiffer crank and block. Although from a driving point of view I do enjoy the high revving ability of my RB. Just IMO Heavier duty, though the engine itself is lighter than the RB IIRC. Link to comment Share on other sites More sharing options...
supracars Posted August 22, 2011 Share Posted August 22, 2011 There is a 1jz engine/ turbo plus loom on ph right now for 380, that would be a better option. Link to comment Share on other sites More sharing options...
TubbyTwo Posted August 22, 2011 Share Posted August 22, 2011 Im not sure the words 'Supra' and 'cheap' go in the same sentence. If you cant afford to fit a TT engine, then leave it NA IMO. Link to comment Share on other sites More sharing options...
