is this too pricey... 1jz gte related
suprasize
  • 2 weeks later...
, but you have to mate it to the Supra harness
...What will I need to mate up a W58 to an auto Soarer engine? Eg bellhousing, ecu etc... =)
Depends where the W58 originated. The easiest option is to start with a complete manual N/A Mk4 Supra, then you have the correct flywheel, clutch, bellhousing, gearlever, and propshaft. :)
You can use the auto Soarer ECU with a wiring mod, but you have to mate it to the Supra harness.
, but you have to mate it to the Supra harnessDepends where the W58 originated. The easiest option is to start with a complete manual N/A Mk4 Supra, then you have the correct flywheel, clutch, bellhousing, gearlever, and propshaft. :)
Thats perfect as mine is an mkiv na manual =) perfect, so all thats needed is to wiring mod and bobs your uncle =)!
