Soopra Posted August 27, 2011 Share Posted August 27, 2011 Lexus Soarers dont exist, much like unicorns. /QUOTE] what, they have a large pointy horn on the front...? Quote Link to comment Share on other sites More sharing options...
Guest BradD Posted August 28, 2011 Share Posted August 28, 2011 Yep theres the Toyota Soarer or the Lexus SC300 and if your looking for a pair of turbos, found a some on eBay.......... http://www.ebay.co.uk/itm/toyota-supra-mk-IV-soarer-lexus-turbo-manyfold-and-pipe-/180713835653?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a13624c85#ht_500wt_1156 Quote Link to comment Share on other sites More sharing options...
suprasize Posted September 10, 2011 Author Share Posted September 10, 2011 Think I should maybe invest in a fully running soarer then, and sell the left overs on ebay... =) what will I need to mate up a w58 to a auto soarer engine? Eg bellhousing, ecu etc... =) Quote Link to comment Share on other sites More sharing options...
garethr Posted September 10, 2011 Share Posted September 10, 2011 , but you have to mate it to the Supra harness...What will I need to mate up a W58 to an auto Soarer engine? Eg bellhousing, ecu etc... =)Depends where the W58 originated. The easiest option is to start with a complete manual N/A Mk4 Supra, then you have the correct flywheel, clutch, bellhousing, gearlever, and propshaft. You can use the auto Soarer ECU with a wiring mod, but you have to mate it to the Supra harness. Quote Link to comment Share on other sites More sharing options...
Abz Posted September 10, 2011 Share Posted September 10, 2011 Interesting route your taking Dan! Power wise, what can you expect from a BPU'd 2.5TT engine? Quote Link to comment Share on other sites More sharing options...
suprasize Posted September 10, 2011 Author Share Posted September 10, 2011 , but you have to mate it to the Supra harnessDepends where the W58 originated. The easiest option is to start with a complete manual N/A Mk4 Supra, then you have the correct flywheel, clutch, bellhousing, gearlever, and propshaft. You can use the auto Soarer ECU with a wiring mod, but you have to mate it to the Supra harness. Thats perfect as mine is an mkiv na manual =) perfect, so all thats needed is to wiring mod and bobs your uncle =)! Quote Link to comment Share on other sites More sharing options...
suprasize Posted September 10, 2011 Author Share Posted September 10, 2011 Interesting route your taking Dan! Power wise, what can you expect from a BPU'd 2.5TT engine? Not too sure, if it's cheaper to go 2jzgte I probably will, ill see how funds are though =) id love a 1jzgte though, all ive heard are good things about them =) Quote Link to comment Share on other sites More sharing options...
