Timing star/trigger wheel removal
Swampy442
You need a pulley puller. There are two threaded holes which you can attach a puller to - it pushes against the centre of the crank and pulls the timing gear off. Unless you already have the gear off and are talking about the timing wheel itself, which is part of the gear - it's not supposed to detatch.
Ive got the crank pulley off, its the one behind, cam belt drive/crank position timing wheel, dont actually know its correct name lol. Basically Im trying to change the front main seal but thats in the way.
Yeah, that's the one. It's the same principle as the main crank pulley, screw a puller in via the two small threaded holes. Something like this one, although this one might be too big:-
http://www.machinemart.co.uk/shop/product/details/cht248-13-pce-harmonic-balance-puller
