New Timing/Aux belts
Guest BradMD
Guest BradMD
Hi, i've been looking around for a set belts to swap all of the belts on my mk4 supra, not sure how many there are as i don't have the car with me but I found this kit on eBay, does anyone know if this kit has all the belts as i don't know how many there are and is it at a good price? Also if someone has some new belts that their not using and would sell for cheaper pm me?
Thanks Brad
Hi Brad,
I would steer clear of Ebay items unless they are from a known specialist. There are too many chinese parts on that site which will only last 5 minutes. Best bet for Supra's is Toyota or known specialist traders. If you are a paid up member then look here where there are good Toyota traders with brilliant discounts who know their apples:
http://www.mkivsupra.net/vbb/forumdisplay.php?24-Members-Chat
Or these guys who are specialists and supply top quality parts:
http://www.mkivsupra.net/vbb/forumdisplay.php?9-Authorised-Traders
Fensport also do a lot of Supra stuff:
http://www.fensport.co.uk/Parts/Model_37/
And Keron is a big help for 2nd hand spares:
http://www.mkivsupra.net/vbb/showthread.php?235140-Kerons-big-parts-Bonanza!!-Aftermarket-stuff-and-some-oem-stuff
For new service items I always go OEM.
Guest BradMD
I'll give toyota a ring and see how much they want for the timing belt and maybe the aux ones too then, if its alright i'll take it from them
Hi Brad,
:think:
The cam tensioner assembly in the Ebay ad is OE assuming it's not a copy part in a copy box. I would get known make belts, what's the point in all that labour to fit a belt from Korea no one seems to have even heard of the make?
Are those definitely OE Chris? I spotted a few of them on ebay and decided to go with Toyota which is a lot more expensive. I assumed they would be in a Toyota box?
Koyo are a high end bearing manufacturer, so if you are happy the box and contents are legit Koyo there shouldn't be an iss ue. A lot of OE Toyota stuff is by Koyo. Toyota, despite their vast size, won't make their own ball and roller bearings, they will buy them in from a specialist.
Ahh, good stuff mate, sets my mind at ease with those tensioners. Off to order one :)
Guest BradMD
TENSIONER BEARING : KOYO JAPAN
TIMING / CAM BELT : MITSOBOSHI JAPAN
ALTERNATOR / FAN BELT : DONGIL KOREA
POWER STEERING BELT : DONGIL KOREA
AIR CON BELT : DONGIL KOREA
says it comes with all 5, timing belt and tensioner from japan, rest from korea.
