JamieP
Jamie
Can't you add a controller that slows it down when cruising/idling etc to help with that and stop premature pump failure?
I have the low voltage controler, i did use it with the setup but still overheated the fuel after long journeys, you could add a fuel cooler if wanted but i went back to a simple setup with staged pumps.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
