JamieP Posted August 18, 2011 Share Posted August 18, 2011 £200 collected. £230 delivered uk. Picture below. Link to comment Share on other sites More sharing options...
JamieP Posted August 30, 2011 Author Share Posted August 30, 2011 Bump. Link to comment Share on other sites More sharing options...
JamieP Posted September 9, 2011 Author Share Posted September 9, 2011 picture. Link to comment Share on other sites More sharing options...
JamieP Posted September 30, 2011 Author Share Posted September 30, 2011 Just looked in the shed, I have two Pre facelift TT6 props as above, i also have one thats a bit shorter so i presume its a TT auto. Link to comment Share on other sites More sharing options...
Andrew K Posted October 1, 2011 Share Posted October 1, 2011 Does the prop pictured go with the v160 box and large case Diff ? I've got a v161 box waiting to go in my motor and that came with the small case Diff! But I'm changing for a large case Diff,Do you know if there's any difference in the length of the 2 props if I'm changing Diffs around? Link to comment Share on other sites More sharing options...
JamieP Posted October 1, 2011 Author Share Posted October 1, 2011 This is for 6 speed/big diff. The facelift setup with small diff uses a longer prop as the diff is smaller, its about 20mm longer iirc, i found this out when i bought a carbon prop for a facelift supra by accident. Link to comment Share on other sites More sharing options...
Andrew K Posted October 1, 2011 Share Posted October 1, 2011 This is for 6 speed/big diff. The facelift setup with small diff uses a longer prop as the diff is smaller, its about 20mm longer iirc, i found this out when i bought a carbon prop for a facelift supra by accident. That's great thanks for the info So if I've got the V161 box and using the large case Diff I'll need this prop then? If so I'll take it then cheers. Link to comment Share on other sites More sharing options...
JamieP Posted October 1, 2011 Author Share Posted October 1, 2011 Yup, you can confirm by measuring your prop flange to flange if you like and i can measure this one, the prop in the picture came off my car though which is 6 speed and big diff. Link to comment Share on other sites More sharing options...
JamieP Posted October 1, 2011 Author Share Posted October 1, 2011 Link to comment Share on other sites More sharing options...
Andrew K Posted October 1, 2011 Share Posted October 1, 2011 Just measured my prop and from flange to flange it's 44 inches long. Link to comment Share on other sites More sharing options...
JamieP Posted October 1, 2011 Author Share Posted October 1, 2011 sounds like you might have the right one already, i just compressed the center joint and its 43.5" flange to flange. Link to comment Share on other sites More sharing options...
Andrew K Posted October 1, 2011 Share Posted October 1, 2011 Just compressed the two halves as far as they would go and it Measured 42.5 inches. Also the sticker on the prop says PA93 if that means anything? Link to comment Share on other sites More sharing options...
JamieP Posted October 16, 2011 Author Share Posted October 16, 2011 Bump. Link to comment Share on other sites More sharing options...
