Clifford Concept 600 alarm question.
RedM
From the Clifford site I read that the Concept 600 system lists Blackjax as a feature.
Is this as standard or do you have to specify it as an optional add-in at installation/purchase? To me it appears to be there as standard but not activated. Am I correct?
If not, approx. how much is Blackjax as an add-on?
Thank you,
According to the install guide it's a Built In Standard Feature.
Lifetime Warranty
His & Hers Remote Controls
ACG™ 2 (Anti-CodeGrabbing™)
Extended Range Receiver
Audible Low-Battery Warning
Built-In Two-Point Immobilizer™
Optional Wireless Immobilizer™
Dual-Zone OmniSensor
Digital Dual-Zone Proximity Sensor 4
Patented UltraSecure Coded Valet Mode™
NightVision™ Headlight Automation
Auto mat ic Post- Parking Il lu mi na tion
Built-In Re mote Head light Ac tivation
Eight-Event TotalRecall™
Enhanced User-Selectable AutoArming
Built-In Window RollUp
User-Selectable Remote Valet Mode Entry/Exit
Built-In BlackJax Anti-Carjacking System
Optional DataPort™ Interface and CliffNet Wizard Pro™ Software
FACT — False Alarm Control and Test
Prewired LED, Sensor, Siren, Extended Range Receiver and PlainView 2 Switch Connectors
High Output Medallion Siren
Dual-Mode “Chirp” Silencing
Remote Siren Silencing
Remote Door Locking/Unlocking with Built-in Relays
User-Selectable AutoLock
User-Selectable AutoUnLock
Integrated Electronic Timer
Turbo Timer Output
CliffNet DataPort Accessory Interface
Remote Keyless Entry and Accessory Activation Even in Valet Mode
Remote Panic with Smart Locking/Unlocking
Smart Remote Trunk Release
Built-In Dual Parking Light Flasher with Onboard Relay
Remote-Controlled Courtesy Lighting
Patented Smart AutoTesting™
Patented Malfunction AutoBypass™ with AutoReMonitoring
Patented Smart Prior Intrusion Attempt Alert
Patented Remote Control Code Learning and MultiRemote Recognition
Clear All Remotes
Multiple-Car Control
High-Luminescence LED Status Indicator with Automatic Battery-Saving Mode
Multiple Sensor/Trigger Inputs
Patented SmartPowerUp™ 2
Full-Time SecureAccess™ Programming
Advanced CMOS Microcomputer
Pre-Loomed Wiring
Three Auxilliary Outputs with Selectable Output Types
AutoActivation of Auxilliary Output C for Window All-Close
Installer-Selectable Door Ajar/Delayed Courtesy Lights
That's how I read it but erm, (how can I put this without giving away my big day?) I know a guy with a car that won't have that car in a few days time and he doesn't think he has Blackjax.
If I was to somehow be in this car in a few days time I'm guessing I should go and get it checked out.
Only thing you have to ensure that's enabled is :
RPM Monitoring
This is required for both RPM-activated automatic door locking and for BlackJax anti-carjacking fea tures. See the RPM Monitoring
section in this binder for information.
Think you could be any more vague? So - you're planning to hijack a car and you want to know if it's going to stop on you? :read:
Yeah, I've come up with this nice way of hijacking a car. It involves handing the owner several thousands of pounds and he gives you the car. Think I'll get away with it?:D
I don't think you've quite got this hijacking thing worked out mate...
Is the PIN code the one mentioned that is on the back of the manual? If not, should the seller know it and pass it on to me?
There is a place to write it on the manual I think. But the owner should definately have it. Otherwise you'll have to reset the system somehow I guess. Don't know if it says in that manual.
