Tyre pressure variation when hot and cold
jim
I'm not great on physics, but understand the principle that air pressure increases as a result of an increase in temperature.
I've got a set of split rims that have been leaking and am testing one that's hopefully been repaired to make sure that it's holding air, so I bought one of those digital pressure gauges to make sure I'm taking consistent readings rather than various different air machines at petrol stations.
I expected there to be a little bit of a difference between a cold reading and a hot one, but I checked this morning before heading to work and the reading was 31.7psi...25 miles later when I got in to work I checked again and the reading was 35.9, which is a variation of about 14%.
For my purposes it doesn't particularly matter as I will compare the cold readings to the cold or hot to hot to see if the pressure is dropping, but I was wondering if this level of change is normal? Does it matter if you inflate your tyres when hot or cold, eg if I inflate to 35 when they're cold then they'll be 40psi when hot, or is that a stupid question? :D
You are on the right track. Temp variances make for quite a difference in pressure. Go to a trackday and see people adjusting tyre pressure constantly as its one of the most important part of getting the optimal grip and tyre wear.
Depending on the cold temperature you start with, I would see it as most sensible to inflate to the wanted pressure when you have the tyre at the temperature mostly use it with. Then just make sure you check you the pressure @ roughly the same tyretemperature each time it doesn't have to be at the same temperature as you when you inflated it.
nitrogen refill will help loads on keeping tyre pressures constant. MGT Racing in Nuneaton have a nitrogen refill machine that will vacuum the air out also. You also have the kwik Fit etc that are now using them. But im not sure i trust them to remove the oxygen out of the tyre first.
