supra-spain Posted August 15, 2011 Share Posted August 15, 2011 Hi, you can say each cable is?in the manuals I can not find Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted August 15, 2011 Share Posted August 15, 2011 The two larger terminals on the left are for the starter inhibitor. Quote Link to comment Share on other sites More sharing options...
EMPEROR Posted August 15, 2011 Share Posted August 15, 2011 http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details&p=3122948&viewfull=1#post3122948 Ask Konrad for the colors... I am pretty sure those are 6 of the wires, the other 3 are for the speed sensor... I guess... Quote Link to comment Share on other sites More sharing options...
supra-spain Posted August 15, 2011 Author Share Posted August 15, 2011 thanks for the answers Quote Link to comment Share on other sites More sharing options...
supra-spain Posted August 15, 2011 Author Share Posted August 15, 2011 This connector is the automatic gearbox, the cables are cut, and not every cable where it mounts to the ecu Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 15, 2011 Share Posted August 15, 2011 (edited) Here's wiring diagram for this plug with colour description and pin numbers and plug itself with pin numbers. Yellow is going to speed sensor number one, could you tell me, what's an exact colour of cables at pins 5 and 6? Edited August 15, 2011 by Konrad (see edit history) Quote Link to comment Share on other sites More sharing options...
supra-spain Posted August 16, 2011 Author Share Posted August 16, 2011 5 black , 6 black/ white ,thanks Konrad Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 16, 2011 Share Posted August 16, 2011 Black goes to pin 77 of large ECU plug, Black/white goes to pin 76 of the same plug. ECU pinouts --> http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13918&d=1112558155 Quote Link to comment Share on other sites More sharing options...
supra-spain Posted August 17, 2011 Author Share Posted August 17, 2011 Black goes to pin 77 of large ECU plug, Black/white goes to pin 76 of the same plug. ECU pinouts --> http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13918&d=1112558155 on ecu pinout 76--NSW--- is yellow 77--STA----in gray ???? Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 17, 2011 Share Posted August 17, 2011 It is possible that those change colour on the way, but unlikely. Is your car na or tt? Quote Link to comment Share on other sites More sharing options...
supra-spain Posted August 17, 2011 Author Share Posted August 17, 2011 Is tt Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 18, 2011 Share Posted August 18, 2011 I'm positive then that I gave you proper colours and pins. Maybe you are looking at big ECU plug from wrong side Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 18, 2011 Share Posted August 18, 2011 Does the yellow wire in the first illustration go to ground or + 12 V? Thanks. Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 18, 2011 Share Posted August 18, 2011 It goes to 12v on speed sensor no.1 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 18, 2011 Share Posted August 18, 2011 Thanks Konrad! Quote Link to comment Share on other sites More sharing options...
