15" Compomotive Drag Wheels / BFGoodrich Radials
jimwire
Selling these on ebay but will end the auction for a forum member.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220832820695&ssPageName=STRK:MESELX:IT
Wheels are 8Jx15. Tyres are 275/50/15.
Bought off Jamie from this thread:
http://www.mkivsupra.net/vbb/showthread.php?242639-15-quot-Drag-wheel-tyres-setup.-SOLD&highlight=drag+wheels+tyres
Only did 6 runs with them on but my car has been lowered so much they hit the arches.
I have been told they will fit a stock height car with the pressures low without issues or a car with rolled arches.
I'd really like to get back what I paid for them As I only did 6 runs with them. That being £300 collected or plus £20 delivery.
Free bump for great wheels/tyre setup. I have these on my supra before Jamie brought them off me and had no problem with them as my arches were rolled. My car was probably the same ride height as jimwire's if not more.
Jimwire, your arches haven't been rolled properly hence the rubbing, i dont thing the ride height has alot to do with the rubbing as no matter how low it is, it'll squat when drag racing anyway. Its all about being able to clear the arches, so guys these tyres will fit a standard supra as long as you have rolled arches. So dont be put off buying these!!!
Heres some pics of my car running them: -
There is a very fine mark but no groove. If I had run them more I'm sure it would have turned into a groove. I can post pictures of the side wall if anyone is interested?
A picture would be good, i may be interested if there is enough rubber left for 1 meeting
Where about are you in Derbyshire?
My supra is lowered, I don't have issues with the arch's on my 17-275-45 but i had issues with my 265-40-18 so i had to raise it a little, changed to 275 and still had no issues. its an arch issue not a width. probably lowered even more than i am. i wouldnt think anyone would have issues unless they have lowered too far on soft setting. stock arch on slightly lowered would be fine, only require rolled archs if you go super low. here is a photo of how low my supra is. i have HSD's and they aren't on soft settting. photo shows AFTER i raised, and no 275 issues, arches are stock.
After destroying a set of brand new MT's at Suprapod 2009 in 2 x 1/4 mile runs i had my arches rolled so there isn't a problem there, i'll need to swap my rear brakes to j-spec which isn't that much of a problem as i've got a set in the workshop, so its just a case of do i want to spend £300 and have i got enough time to get it sorted before Oct 15th :D
Im only botherd about the wheels as the tyres would need changing pretty quick
Go for it and buy them i'm sure you would notice a big improvement in times on the 15th :thumbs:
Only another £400 to re rubber thhem when you use that set of tyres up.
Are you in j-spec break already?
