Guest carmsbody Posted August 14, 2011 Share Posted August 14, 2011 just thought id let you all know what i found on ebay, have not seen these before sold anywhere. made and sold in australia. a windage tray is a medal tray that is bolted to the main caps on the bottom of the engine that is designed to keep the engine oil from splashing up in the engine and stop the oil pump pick-up tube from sucking air instead of oil. It also stops the engine oil from foaming in the oil pan due to splashing. and the baffle box is to reduce the movement the oil in your sump when you corner/brake/accelerate. if you read the listings on ebay it goes into this a little... google is your friend DISCUSS SURGE PLATE/BAFFLE BOX suit Toyota Supra 2JZ-GE/GTE SURGE PLATE/BAFFLE BOX suit Toyota 2JZ-GE/GTE RACER WINDAGE TRAY suit Toyota 2JZGE-GTE with rear sump-SUPRA pictures from ebay listings Quote Link to comment Share on other sites More sharing options...
Guest carmsbody Posted August 20, 2011 Share Posted August 20, 2011 Really.... no one has anything to say Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 20, 2011 Share Posted August 20, 2011 isn't there a stock baffle plate? it's not so fancy but there is one.......perhaps a good addition to those top end builds for safety? Quote Link to comment Share on other sites More sharing options...
bignum Posted August 21, 2011 Share Posted August 21, 2011 I dont think many people if any have suffered oil starvation due to cornering or acceleration forces, on here anyway. Quote Link to comment Share on other sites More sharing options...
