Breaking 1998 facelift supra
Ibrar Jabbar
  Stevo said:
Hi Ibrar,
As per my PM the other day, I'm after the thin aluminium retaining strips that are used to fix the stock front lip (not the active one) to the underside of the front bumper - need the straight (centre) and curved sections on both sides please.
Cheers
Still havn't had a chance to check them yet, will get back to you mate.
  • Replies 98
  bodilx6 said:
  Ibrar Jabbar said:
Which bypass valve you after, do you have a pic of it?
No, sorry. I can find a picture from the TSRM maybe. Is't the standard one people often replace with an aftermarket Blow Off Valve. So if the car has a BOV the OEM bypass valve probably isn't fitted anymore.
Anything on this?
