Scott Posted August 11, 2011 Share Posted August 11, 2011 What requires modding/plugging/shouting at in order to swap a jspec manifold for a UK spec one? Is it a big job? I seem to remember an EGR port or something needing plugged up but I thought that was it? Also, what is the easiest way to tell if you have a UK spec manifold? I'm not sure if the one I have is or isn't. Thanks guys. Quote Link to comment Share on other sites More sharing options...
mr lover Posted August 11, 2011 Share Posted August 11, 2011 The ridge on the top of the manifold runs down the centre on a Jspec and to the side on a uk Quote Link to comment Share on other sites More sharing options...
Scott Posted August 11, 2011 Author Share Posted August 11, 2011 The ridge on the top of the manifold runs down the centre on a Jspec and to the side on a uk Easy way to spot, cheers Quote Link to comment Share on other sites More sharing options...
Scott Posted August 11, 2011 Author Share Posted August 11, 2011 Would I be right in saying this is a jspec then? Quote Link to comment Share on other sites More sharing options...
mr lover Posted August 11, 2011 Share Posted August 11, 2011 uk one Quote Link to comment Share on other sites More sharing options...
Scott Posted August 11, 2011 Author Share Posted August 11, 2011 Ideal, definitely a jspec then. Thanks Quote Link to comment Share on other sites More sharing options...
mr lover Posted August 11, 2011 Share Posted August 11, 2011 Jspec Quote Link to comment Share on other sites More sharing options...
mr lover Posted August 11, 2011 Share Posted August 11, 2011 beat me too it, Quote Link to comment Share on other sites More sharing options...
Kristian_Wraae Posted August 11, 2011 Share Posted August 11, 2011 (edited) The UK spec doesn't have the the hole for the temp sensor. It has a vacuum port more at the back. The bracket that holds the accelerator cable is not interchangeable between the jspec and the uk spec - spacing of holes is different so filing is required. No EGR on the jspec. Edited August 11, 2011 by Kristian_Wraae (see edit history) Quote Link to comment Share on other sites More sharing options...
