Fitting blitz boost controller
jackso11
I am going to do this at the weekend, have all the parts apart from the T-piece which I am struggling to find however I am a little confused from the instructions.
From the install manual it seems you need to T the hoses coming from the solenoid and connect to both turbos. But from the online guides it seems you don't T those hoses, you cap off the VSV and connect the solenoid to one actuator, which is correct? If it is capping off the VSV, what do I use to cap them off? No caps with the boost controller.
This is the guide I found:
http://www.mkiv.com/techarticles/blitz_dsbc/index.html
