bradleyh_15 Posted August 9, 2011 Share Posted August 9, 2011 As the title says a strange high pitched whistle has developed on my supra from behind the throttle body any one know what it is? Video of noise hear Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 9, 2011 Share Posted August 9, 2011 Is it there all the time or only at tickover Brad? Have you checked all the intercooler pipework to be sure nothing is loose? Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted August 9, 2011 Author Share Posted August 9, 2011 Is it there all the time or only at tickover Brad? Have you checked all the intercooler pipework to be sure nothing is loose? Should have said I checked all the intercooler pipework and tightened all the couplings and clips. It is at tick over and partial throttle but then disappears. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 9, 2011 Share Posted August 9, 2011 The next thing I'd check would be the butterfly valve in the throttle body. See if that is seating properly. Sometimes they get fouled up and don't close properly which might lead to a whistle in the system. Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted August 9, 2011 Author Share Posted August 9, 2011 The next thing I'd check would be the butterfly valve in the throttle body. See if that is seating properly. Sometimes they get fouled up and don't close properly which might lead to a whistle in the system. Thanks mate I'll give that a check tomorrow Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted August 14, 2011 Author Share Posted August 14, 2011 Any other ideas?? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 15, 2011 Share Posted August 15, 2011 Remove the serpentine belt and start the car, BUT ONLY FOR A VERY SHORT TIME, just to make sure that it's not coming from the power steering system or indeed another pulley. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 15, 2011 Share Posted August 15, 2011 Pfft can run the car for ages with the belt off without worry Sounds like a washing machine on high spin Quote Link to comment Share on other sites More sharing options...
FOSTA Posted June 14, 2013 Share Posted June 14, 2013 I know this is an old thread but Looks like I have exact the same problem! With me being NA-t and having a FFIM my throttle body sits in the same place. It only dose it to around 2k revs then stops if you go past, its very annoying as its so loud when stepping back off the throttle! It sounds like somthing to do with inlet pressure as it Dosnt get louder or change tone the faster you go its the same tone all the way through but if your going up hill for example it will stop making the noise at say 1.5k and going down hill it will stop when you reach 2.8-3k revs. My inlet pressure on my TRU boost gauge is showing up perfect and so is my A/F on my wide band so I don't think its a vacume leak, and with it being the same as the op above I'm sure its the power sterring pump! Has anybody else experienced this just before I try and swap them out? Or could it be that it needs bleeding? I know normally its a grinding noise when it needs bleeding but might be worth a try. Thanks guys Quote Link to comment Share on other sites More sharing options...
