pete_TT Posted August 9, 2011 Share Posted August 9, 2011 Used AEM Air fuel ratio gauge Info: AEM’s Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring! Key Features: • Bosch sensor included! • 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio AFR • Integrated three-digit display reveals AFR in real time • User-programmable 0-5v analog output included for use with data loggers and ANY engine management system • Ideal AFR monitoring tool for carbureted applications and engine dynamometers • Does not oscillate AFR like narrow band sensors • Serial data stream included for output of AFR (RS 232) • Accurate to 0.1 AFR Everything is included apart from the weld on boss that the sensor screws into as it is still welded to my exhaust. Easily replacable from most tuning companys. Price: SOLD Link to comment Share on other sites More sharing options...
Black_Supra Posted August 9, 2011 Share Posted August 9, 2011 pmd Link to comment Share on other sites More sharing options...
