Na clutch upgrade
Marco79
When running nitrous I'm getting clutch slip in 4th and am looking into an upgrade, would a tt clutch be better/compatible? Or has anyone any suggestions as too an alternative? The car is running in the range of 320-330bhp if that helps?
TT 6spd clutch won't fit. Unfortunately the options are a bit limited on the w58. There are no organic plate clutches I've found so far that are going to be much use above 300lb/ft, so you're going to be looking at puck clutches (Horrible things IME). The one Craig suggests above should certainly hold the power, but will be a puck one.
Lol :D my clutch knowledge is slim, it's my new area of learning lol what is it about a puck clutch that you don't like mate?
Engagement and drivabilty. It's a bit of a generalisation, but puck clutches will have a fairly harsh engagement. By design they are very on/off, but need to be to acheive the torque ratings they do. My own supra is a daily driver and I would never have a puck clutch on it.
puck clutches are not as smooth as organic , and the engagement is harsher , but they cool quicker and often hold more torque
So in short would it detract from the street driving experience or is it just something u get used to?
