bodilx6 Posted August 8, 2011 Share Posted August 8, 2011 I'm having a strange "spoinnng"-ish sound from my left rear wheel arch. Originally I heard it years ago, but ONLY in the wet (?!). Then I had a CW suspension fitted by the man himself and it sort of dissappeard for a year or two. Now its back with a vengeance. Always there when I hit bumps on a camber or when I move off from a stop at normal speed. I don't hear it over 40-ish mph but that could be road noise cancelling it out. Not sure. Doesn't sound like a "thump" but more as metal contacting metal, lightly, or some metal "releasing tension". I've tried - by hand - to pull/push the suspension arms with the wheel off, but I dont see any apparent movement in the bushes except I can "slide" the arm a mm or so along its axis. I wonder it is a bushing issue (if so, I'm contemplating replacing all arms but that is WAY expensive) or if i need to re-torque something (if so, what?). Here are pics of most suspension joints/bushes. http://idisk.me.com/stefanbovien/public/suspension/SUSP_01.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_02.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_03.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_04.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_05.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_06.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_07.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_08.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_09.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_10.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_11.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_12.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_13.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_14.jpg http://idisk.me.com/stefanbovien/public/suspension/SUSP_15.jpg Any input appreciated. I'm having a hard time figuring out how to diagnose this, so any ideas about that are welcome as well. Thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 It *MAY* be the bush in the lower arm the damper stirrup bolts through is worn, but you can't buy them without buying a new lower arm. Similarly the top wishbone inner spherical bearings wear, and again, it's a new wishbone job. BUT I have to just guess here, nothing stands out as knackered in the photos. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 8, 2011 Author Share Posted August 8, 2011 Thanks Chris, thats kind of what I was guessing to hear. I don't see anything wrong anywhere, but its reassuring that you don't see it either. I'll soon get the chance to have Toyota DK's tech troubleshooting guru to take a ride with me. He might have an idea. Else its going to be new whishbones from Toyota I think. Is there anything else that would be a good idea to replace in the same round? Btw, anything on the springs I mailed you about for the OEM Toyota/Bilstein dampers? I will be near your place around the 12th or 13th of September I think. /Stefan Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 They'll be ready next week, no worries. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 9, 2011 Author Share Posted August 9, 2011 Sweet! You just send me a mail and I can get the guy to send you some cash. I would rather do that so all is OK for pickup when I get there. Oh, one thing; what should he expect after a lowering with your springs in combo with the bilsteins from the basic OEM suspension he is running now? Link to comment Share on other sites More sharing options...
