bodilx6 Posted August 8, 2011 Share Posted August 8, 2011 I'm after adding a SLD to that, but if that is the cruise ecu, I'm sh*t out of luck unless someone has a really good idea of how to get the that plug or to get to the speed wire (pink one I think) where it "braches" out from the ODO signal. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 9, 2011 Author Share Posted August 9, 2011 Noone knows? Link to comment Share on other sites More sharing options...
neilp9876 Posted August 9, 2011 Share Posted August 9, 2011 I'm not 100% certain but I'd say it is. I do know its tucked away in the very depths of the dashboard because I wanted to cut the wire so that the cruise worked above 70mph, but unless your stripping the whole dash or have fingers that are 12 inches long and as thin as a match, I couldnt see how you could do it. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 10, 2011 Author Share Posted August 10, 2011 Thats the same conclusion I got to.... bugger... A possible solution *COULD* be to wire in a SLD at the very top of the "chain", on the pink wire from the ODO. This does also mess with the other systems like the active spoiler and the speed dependant power steering. However, I actually had one installed there for years and only found the active spoiler to be the difference. At least I didn't notice any other differences. It could be installed so it was working by a switch, so it can be turned on when driving across europe or so.. It's not the best solution though.. Link to comment Share on other sites More sharing options...
neilp9876 Posted August 10, 2011 Share Posted August 10, 2011 Not sure how its wired in, but my active spoiler and PAS are both in mph and work correctly, its just the cruise that got missed out. If you do find an easy solution then do let us know. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 10, 2011 Author Share Posted August 10, 2011 Exactly. PAS and spoiler works when you fit a SLD to the main ECU by the passenger footwell as the main ECU is the last point in the speed signal chain. I will look more into it... Link to comment Share on other sites More sharing options...
