mwilkinson Posted August 7, 2011 Share Posted August 7, 2011 Was wondering what people thought about installing new oil squirters on my engine build? I know they can be cleaned with compressed air but would it be advisable to change these? Are they prone to blocking and what would be the consequences if one did? Just for info I have no reason to suspect they are damaged or not working, but I did find this on the number 4 rod. There is no obvious damage to the crank but its going away to be looked at. Would a failed oil squirter cause this? Quote Link to comment Share on other sites More sharing options...
SimonB Posted August 7, 2011 Share Posted August 7, 2011 Just clean/degrease them and check the springs by poking them with something. They are there to cool the underneath of the pistons, they won't make any difference to the crank/rod lubrication. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted August 7, 2011 Author Share Posted August 7, 2011 Just clean/degrease them and check the springs by poking them with something. They are there to cool the underneath of the pistons, they won't make any difference to the crank/rod lubrication. Cheers Simon will do. On aside note any comments on the bearing wear you can see above? Quote Link to comment Share on other sites More sharing options...
dude Posted August 7, 2011 Share Posted August 7, 2011 Matt drop em off with the block and ill sonically clean em for you. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted August 7, 2011 Author Share Posted August 7, 2011 Matt drop em off with the block and ill sonically clean em for you. Cheers John, will do. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 Looks like you have a bent rod, or bent crank, that wants checking out properly. Quote Link to comment Share on other sites More sharing options...
Hellstrom Posted August 8, 2011 Share Posted August 8, 2011 I would replace them its not alot money and if the spring has become abit Worn that would need less oilpressure to open the valve and you would get lower oilpressure in the whole . you could check them useing the tsrm manual to check if the spring pressure is accordingly. I did change em when i rebuilt my 7m engine. (was no brakedown, just wanted a 1000hk + bottom end) --- I am here: http://maps.google.com/maps?ll=57.729185,11.785945 Quote Link to comment Share on other sites More sharing options...
