AMG Posted August 16, 2011 Author Share Posted August 16, 2011 Just thinking, that was a bit harsh lol. It might not be goosed, it might just be a line has split/disconnected. It most likely won't be the pressure tank as I think that when it is fooked the 2nd tubby will still come online... it'll just be a lot later. It's been a while since I went through all this stuff though. Its all good mate. I have learnt a lot more than i thought i would about the system. Any opinions nd comments are always good. Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 16, 2011 Share Posted August 16, 2011 Have a read through here if you haven't already: http://www.mkivsupra.net/vbb/showthread.php?35926-The-sequential-system Sounds like you have problem number 1. You can try the tinfoil strip trick to see if the IACV is opening or not. Fold up a bit of tinfoil into a thin strip (think squashed rollup cigarette size) and trap one end between the actuator and the stop of the IACV. Go for a drive. If the tinfoil strip is still there after the drive, it didn't open up Quote Link to comment Share on other sites More sharing options...
AMG Posted August 18, 2011 Author Share Posted August 18, 2011 Thanks Ian. I will give that a go at the weekend. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 18, 2011 Share Posted August 18, 2011 Half the sequential vac / pressure plumbing issues I sort out are caused by schonkky silicone hoses that have to be secured with tie wraps. Proper new "black rubber" hoses that are a proper tight push on fit, and don't have a propensity to split from the ends inwards, like bling silicone, are what you want. Show me a proper factory race engine with silicone vac / pressure hoses for air, apart from proper braided stuff for the intercooler. Quote Link to comment Share on other sites More sharing options...
AMG Posted August 18, 2011 Author Share Posted August 18, 2011 I will take that on board and replace all my hoses i think then Chris. There are only a couple of silicone ones but its worth the reassurance. Quote Link to comment Share on other sites More sharing options...
AMG Posted August 20, 2011 Author Share Posted August 20, 2011 Thanks for all the help everyone I have finally sorted it. It ended up being a very hard and brittle vac line going to the egcv. All sorted but not before finding a IACV and a egbv in a box of spares in my garage I think I will look into the ettc mode now then. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 20, 2011 Share Posted August 20, 2011 Good stuff Quote Link to comment Share on other sites More sharing options...
jimwire Posted August 20, 2011 Share Posted August 20, 2011 Are you replacing it with a stock one? I want to replace my old hoses but want to use the right stuff. Is there a list with part no's anywhere on here (I have searched) or failing that what would people recommend? Quote Link to comment Share on other sites More sharing options...
AMG Posted August 20, 2011 Author Share Posted August 20, 2011 For now I got some 5mm diameter vacuum hose from halfords which fit perfect and nice and tight. I think I will try and replace them all with new Toyota pipes though. Did you say you had an intermittent problem with boost? Quote Link to comment Share on other sites More sharing options...
jimwire Posted August 21, 2011 Share Posted August 21, 2011 Yes. I have traced it to the electrical connectors to the IACV and EGCV. got them ordered. Also got a full set of vsv's in case. I'll be checking all the hoses though as well. Quote Link to comment Share on other sites More sharing options...
