stevie_b Posted August 6, 2011 Share Posted August 6, 2011 This could be of interest if any of you or your other halves are into cross-stitch, painting or other craft work. Genuine Daylight Company free-standing floor lamp, with magnifying glass and clamp. "Daylight" is a good make of this kind of lamp. The lamp, magnifier and clamp are all on independent flexible stems, so their positions can be adjusted independently of each other. It has a foot switch built-in to the power cable so it can be turned on or off without using your hands. It has a maximum height of about 5 foot. It's finished in a metallic brass colour. It has a weighted base so that it doesn't topple over no matter what the positions the flexible stems are in. The base is on castor wheels to make it easy to move around the house. The base has a few small scratches in the finish, but these don't detract from the look of the unit. Other than these scratches, the whole unit is in perfect condition. The magnifying glass is in perfect condition, with no chips or scratches. It has a soft sleeve to protect it when not in use. The lamp is fitted with a genuine Daylight 20 Watt low-energy bulb. Because of the weight and size, this is collection only from Basingstoke. £50. [ATTACH=CONFIG]136915[/ATTACH] Link to comment Share on other sites More sharing options...
