hackin_n_bashin Posted August 5, 2011 Share Posted August 5, 2011 Urgently need a crank pulley tool for the weekend, does anyone in the Midlands have one I can borrow? Adam Quote Link to comment Share on other sites More sharing options...
Jezz Posted August 5, 2011 Share Posted August 5, 2011 I did have one, but I dropped it down the drain on my drive. Quote Link to comment Share on other sites More sharing options...
al02uk Posted August 5, 2011 Share Posted August 5, 2011 If you want to remove the pulley, you could wedge a breaker bar under the o/s chassis whilst connected to the pulley. If you turn the key for about 1 or 2 seconds, it will spin the bolt off Sounds dodgy....because it is, but it does work Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 5, 2011 Share Posted August 5, 2011 I have one, its not mine but of youre desperate you can borrow it. I need assurances Ill get it back. Quote Link to comment Share on other sites More sharing options...
sim1987 Posted August 5, 2011 Share Posted August 5, 2011 i removed mine not to long ago used a couple of bits of screwed bar drilled a peace of flat plate and drew it of using the crank bolt worked a treat.to crack the bolt brecker bar and scaff pole with the car in a high gear dodgy but works. Quote Link to comment Share on other sites More sharing options...
Iky Posted August 5, 2011 Share Posted August 5, 2011 I would have sent mine by curior but a chap on here has it and hasn't remembered to send it back Try sending spiderpigcity a pm and tell him to send mine direct to you. Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 6, 2011 Author Share Posted August 6, 2011 I did have one, but I dropped it down the drain on my drive. Oh Jezz, you are special! I have one, its not mine but of youre desperate you can borrow it. I need assurances Ill get it back. Pm'd mate Quote Link to comment Share on other sites More sharing options...
Hoppy Posted August 9, 2011 Share Posted August 9, 2011 If you still need one: http://www.ebay.co.uk/itm/220692239411 I used this same kit yesterday to remove my OEM pulley. Works a treat Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 9, 2011 Author Share Posted August 9, 2011 All done. Big thanks to Craig (swampy) Quote Link to comment Share on other sites More sharing options...
scotty71 Posted August 9, 2011 Share Posted August 9, 2011 Urgently need a crank pulley tool for the weekend, does anyone in the Midlands have one I can borrow? Adam you and tool go hand in hand.... all sorted yet mang? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 9, 2011 Share Posted August 9, 2011 No worries Adam, thanks for the quick return and great to meet you Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted September 5, 2011 Share Posted September 5, 2011 As an update on this, does anyone have on i can borrow lol. Desperate to get mine changed this weekend after my outer pulley flew off and smased at the weekend. Quote Link to comment Share on other sites More sharing options...
Iky Posted September 5, 2011 Share Posted September 5, 2011 As an update on this, does anyone have on i can borrow lol. Desperate to get mine changed this weekend after my outer pulley flew off and smased at the weekend. Sent you a pm mate. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted September 5, 2011 Share Posted September 5, 2011 thanks mate. Quote Link to comment Share on other sites More sharing options...
