Si_s Supe Posted August 5, 2011 Share Posted August 5, 2011 As mentioned in another thread, I bought a 2nd Decat a while back and have been keeping my eye out for a 3" 1st Decat but then this all in one Decat pipe came up from a mate who bought it for his single without realizing it wasn't v banded!! Anyway, I offered it up against the Decat I've already got and it seems to follow a different route! Any ideas? Also has a sensor hole that the 2nd Decat doesn't have. I know it came from America and is really nicely made but are the US exhausts different to j specs?? Quote Link to comment Share on other sites More sharing options...
TRD DAN Posted August 5, 2011 Share Posted August 5, 2011 If it's for a UK spec ? Then the flange that bolts to the turbo is different I belieave ? Dan Quote Link to comment Share on other sites More sharing options...
tony tt Posted August 5, 2011 Share Posted August 5, 2011 Yeah as above the flange on the uk decat is bigger than the j-spec. All in one decat pipe? Not sure what the longer one is off at all. Sensor hole could be for en egt guage probe or afr 02 sensor probe. It doesnt look right at all. It's not an N/A decat is it? Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted August 5, 2011 Author Share Posted August 5, 2011 Right, thanks guys. I'll check the flange later and see if it's right. At the moment though, it looks like I'll be getting a refund off my mate. That is always the downside of buying from mates, it can be a problem when it all goes Pete Tong!! Quote Link to comment Share on other sites More sharing options...
tony tt Posted August 5, 2011 Share Posted August 5, 2011 Do you have the first decat already? The shiney one just looks all wrong mate. Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted August 5, 2011 Author Share Posted August 5, 2011 No I haven't. I did buy one 2nd hand off the forum but it's the most shonky looking thing you've ever seen so needless to say it's not going anywhere near my car! Quote Link to comment Share on other sites More sharing options...
SimonB Posted August 5, 2011 Share Posted August 5, 2011 If he bought it for a single then it would be different since the turbo is in a completely different place. It would only fit the particular turbo/manifold/pipework that it was designed for. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 5, 2011 Share Posted August 5, 2011 The shiney one is a double decat... all in one Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted August 6, 2011 Author Share Posted August 6, 2011 The shiney one is a double decat... all in one So you think it's right?? It is meant to be an all in one double Decat but looking at the straight section on the two pipes they're running at different angles!? It's a Megan Racing pipe. Quote Link to comment Share on other sites More sharing options...
mr lover Posted August 6, 2011 Share Posted August 6, 2011 the 3 hole flange will be too big for sure, if it came from america Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 6, 2011 Share Posted August 6, 2011 Wrong flange at the turbo elbow end, it's for UK / European engines, not Jap spec, probably won't fit a RHD car anyway. Quote Link to comment Share on other sites More sharing options...
Si_s Supe Posted August 6, 2011 Author Share Posted August 6, 2011 Balls!! Back to the drawing board then. Hopefully he'll give me my money back. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 6, 2011 Share Posted August 6, 2011 Looks ok to me. If you look at the non shiney one, you will see the end of it angles to make it the same degree as the shiney one. It's just taking a slightly less direct route. Pretty sure it will be fine, there is a bit of wiggle room where the decats go anyway as the cats are quite large. Quote Link to comment Share on other sites More sharing options...
JODY T Posted August 6, 2011 Share Posted August 6, 2011 I have a uk spec double Decat on my vvti, obviously it didn't fit but I took my old cat and the pipe to a fabricator and they cut the flags off and welded the correct one, cost me 60 quid.. Fits just fine now Quote Link to comment Share on other sites More sharing options...
