dr_jekyll Posted August 4, 2011 Share Posted August 4, 2011 looking for a good quality reg please. second hand is fine Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 8, 2011 Author Share Posted August 8, 2011 bump , getting urgent Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 What's wrong with the stock one? I have Bosch Motorsport ones in stock, but they are pricey. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 8, 2011 Author Share Posted August 8, 2011 i want to up the fuel pressure a little just to squeeze a bit more through the injectors without using too much duty cycle Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 http://www.bosch-motorsport.de/content/language2/html/2829.htm You need the alloy holder as well as one of the regs. They are dear but it is a VERY important item, if the pressure drifts it upsets the map out of closed loop. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 8, 2011 Author Share Posted August 8, 2011 id love one of those but my bugit for the rest of the season is thin. ive heard the aeromotive , sard and tomei are reliable. what do you think of them ? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 I think Tomei stuff is very good. If you have a spare stock FPR you could try an old trick I used years ago, in series where you had to leave the ecu stock, but wanted to richen the engine up (pre closed loop wideband stuff). You can sometimes crush the top capsule with the spring in it in a vice, sometimes using sockets to apply the compression. If you do it a bit at a time and test it you can raise the fuel pressure of a seemingly stock and sealed FPR at zero cost. NISMO ones are very good and have AN6 fitting tails: http://www.sumopower.com/product/view/3400 Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 8, 2011 Author Share Posted August 8, 2011 i have 4 stock pressure regs , thats exelent , it may seem abit tight of me but every little helps at the moment . Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 Not at all, I have done some simply dreadful things when money is tight. It's a perfectly legitimate mod, in many early saloon car series if you DIDN'T do it you were slow Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 I have never weighed it up but I know people drill the top of stock Nissan regulators and silver solder a nut on, and use a bolt and locknut to adjust the spring pressure, and hence the fuel rail pressure. You would need to careful not to kill the diaphragm with the heat though, maybe doing it partly submersed in water? Have a close look at the Nismo one I linked to above. The top of the spring would have to abut a washer or something though, not just the shell of the regulator, You might have to sacrifice one and cut it open to have a weigh up. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 8, 2011 Author Share Posted August 8, 2011 i will chop one up tomorrow , thanks for all you help chris , on this and regarding my suspension set up , i do apriciate it Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2011 Share Posted August 8, 2011 It's nice to see someone driving one in anger further than a 1/4 mile Link to comment Share on other sites More sharing options...
Paul R Posted August 9, 2011 Share Posted August 9, 2011 I've got an FPR - not sure of the make. i'll have a look later and see if I can see what it is. you'll need a guage to set it up though. Paul. Link to comment Share on other sites More sharing options...
