Hesitating on throttle?
markybhoy86
Hi all
This has been happening for a while now but Ive not bothered my arse getting round to finding out the problem. Mostly from cold when I accelerate it seems to take a few seconds for it to react,then as if it catches up it goes. It happens when the car is up to temp as well,if I'm on the motorway and drop a gear,foot down,it doesn't want to pull for a few seconds then it catches up.
Any ideas or things I can check?
Ps before Scott says I'm a mechanic,I'm not anymore :p back to the engineering trade.
Forgot to say : it's a tt manual,decat,boost controller set to 1.2,plugs gaped to whatever the setting on here told me .8 I think it was.
your 0.1mm out on the gapping for a start :D - upto 1.2 bar is 0.7mm IIRC
maybe a sticky actuator? or gay driving :D
Aww mate ur patter is class....try again fs
Anyway back onto my point,how can I check my egr?il pull the plugs out over the weeken and il double check what I've set them to
Cheers
Can you describe what is happening in more detail, I don't understand what you mean by "it catches up"? Are you saying there's a delay with the turbo(s) coming online, or the engine revving but you're not getting drive (ie. worn clutch), etc.
If i have changed gear and I put my foot down it feels like nothing is happening and after a few seconds it shunts up to speed,happens a lot when cold but I've noticed it a few times when I have changed gear?
I hear the turbo spool up but it's not revving or spooling in a way that it would be a worm clutch,they seem to stay the same until the jerk/hesitation has went away
What revs are you at when this is happening? If you are going from say 4th to 3rd and it takes you to 4k+ RPM you might see a delay in the turbos spooling. This can be made a lot worse if the IACV VSV is on the way out. I've seen it a few times where the 2nd turbo doesn't spool when dropping down and it often took to over 5k before the power came on properly.
Is there a way I can check the tsp and egr?I'm going to pull the plugs out today and check my gap,positive I set it properly but never know
Tps is a resistance check. Simply unplug and check the resistance across the pins. Should be a certain value at open and a certain value at closed. Limits are in the manual.
Best thing to do with the egr valve is take it off and clean it. I'm sure geo did a tutorial on that a while back.
Check the coil pack clips when you're checking the plugs, just to rule them out.
