squeaky cluth
Guest matthew14
Guest matthew14
Can anyone help my clutch has been sqeaking every time i push i down if the car is running or not i ve had it for about 2 years and it does not affect the running of the supra SZ but is annoying lol. Anyone got ideas how to shut it up i have tried WD40 on the pedal as it goes thought the fire wall from inside the car.
Many thanks
Nah, its just dry joint, a bit like a squeaky spring joint. Greasing would help temporarily but with the way the clutch is in use like it is,it dries up all too quickly.
Ive had my car for a year and half with that problem now. Just had to put up with it. That's all.
+1, just turn up the stereo.
It will need replacing
Your kidding right :blink:
With the correct type and amount of grease on the ball the fork locates onto and where the slave pushes against the fork it will stop squeaking for good but its a box out job to do it properly.
Bare in mind also the pedal can squeak as well. A quick greasing of the springs usually shuts it up.
But we aren't on about the pedal. And its pretty expensive to get the box out and grease it, you might aswell get a few other stuff done while you are at it.
