Guest matthew14 Posted August 3, 2011 Share Posted August 3, 2011 Can anyone help my clutch has been sqeaking every time i push i down if the car is running or not i ve had it for about 2 years and it does not affect the running of the supra SZ but is annoying lol. Anyone got ideas how to shut it up i have tried WD40 on the pedal as it goes thought the fire wall from inside the car. Many thanks Quote Link to comment Share on other sites More sharing options...
Attero Posted August 3, 2011 Share Posted August 3, 2011 It's the clutch fork. It will need replacing and it's very expensive. Mine has the same, but I cannot justify paying out hundreds just to get rid of a squeak. Quote Link to comment Share on other sites More sharing options...
Guest matthew14 Posted August 6, 2011 Share Posted August 6, 2011 thanks for that. the squeek isn t a sign is going to fail or anything is it? Quote Link to comment Share on other sites More sharing options...
Attero Posted August 6, 2011 Share Posted August 6, 2011 Nah, its just dry joint, a bit like a squeaky spring joint. Greasing would help temporarily but with the way the clutch is in use like it is,it dries up all too quickly. Ive had my car for a year and half with that problem now. Just had to put up with it. That's all. Quote Link to comment Share on other sites More sharing options...
L18msy Posted August 6, 2011 Share Posted August 6, 2011 Nah, its just dry joint, a bit like a squeaky spring joint. Greasing would help temporarily but with the way the clutch is in use like it is,it dries up all too quickly. Ive had my car for a year and half with that problem now. Just had to put up with it. That's all. +1, just turn up the stereo. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 6, 2011 Share Posted August 6, 2011 Is it coming from inside the cabin or outside? Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted August 6, 2011 Share Posted August 6, 2011 The clutch fork is not that expensive, I got one for my V160 from Toyota and it was around £60 ish (I think) Quote Link to comment Share on other sites More sharing options...
Kirk Posted August 6, 2011 Share Posted August 6, 2011 It will need replacing Your kidding right With the correct type and amount of grease on the ball the fork locates onto and where the slave pushes against the fork it will stop squeaking for good but its a box out job to do it properly. Bare in mind also the pedal can squeak as well. A quick greasing of the springs usually shuts it up. Quote Link to comment Share on other sites More sharing options...
Attero Posted August 7, 2011 Share Posted August 7, 2011 Your kidding right With the correct type and amount of grease on the ball the fork locates onto and where the slave pushes against the fork it will stop squeaking for good but its a box out job to do it properly. Bare in mind also the pedal can squeak as well. A quick greasing of the springs usually shuts it up. But we aren't on about the pedal. And its pretty expensive to get the box out and grease it, you might aswell get a few other stuff done while you are at it. Quote Link to comment Share on other sites More sharing options...
