Windows slow up/down
bodilx6
I think I remember my driver's side window doing this, it turned out to be the window winding mechanism. The cable was getting frayed, and eventually broke (then the window fell into the door). You can replace the mechanism separate from the motor though, don't think it was that much money from what I can remember.
It's not by battery either. It's been working at the same speed the 6 years I've had the car, so it might just be originally designed like that? I'll try to see if a bit of sillicone might work. If so, new mechanisms is the way forward. It's annoying to wait 5-6 sec per window when you park (or 8-10 sec or so if I do it at the same time)
