Guest drummerboy08 Posted August 2, 2011 Share Posted August 2, 2011 Has anyone ever seen this done? Is it possible to replace the 5 speed manual in the N/a with a 6 speed manual box from a TT? I'm wondering is it an easy enough job to do, or does it take a bit of trickery to fit? Quote Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted August 2, 2011 Share Posted August 2, 2011 my N/A has the 6speed box but it's factory my first question would be why would you want to change the 5spd na to a 6spd? Quote Link to comment Share on other sites More sharing options...
dude Posted August 2, 2011 Share Posted August 2, 2011 Why would you want to put a 6 spd in an NA Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 2, 2011 Share Posted August 2, 2011 Why would you want to put a 6 spd in an NA I'm guessing to get ready for a TT conversion at a later date when insurance is more favourable... but if that's the case the gearbox will push up the insurance too Quote Link to comment Share on other sites More sharing options...
dude Posted August 2, 2011 Share Posted August 2, 2011 I would put the TT in first then go for a 6 spd if i ever broke it. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 3, 2011 Share Posted August 3, 2011 i want that but purely for motorway cruising Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 3, 2011 Share Posted August 3, 2011 i want that but purely for motorway cruising There is feck all difference between a 5 & 6 speed in that respect. The top ratios are nearly identical, the 6 speed is just a closer ratio box requiring an extra gear to get there. A final gear (diff) change is a far cheaper option for better motorway cruising. But acceleration will be sacrificed somewhat. If you are set on a 6 speed box a diff change will be required anyway. Quote Link to comment Share on other sites More sharing options...
Guest drummerboy08 Posted August 3, 2011 Share Posted August 3, 2011 I'm guessing to get ready for a TT conversion at a later date when insurance is more favourable... but if that's the case the gearbox will push up the insurance too This is the main reason, but I was also hoping that it would make things a little better for the motorway. I was also curious to see if it was an easy enough job to do. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted August 3, 2011 Share Posted August 3, 2011 The 5 is a nicer box IMO. Quote Link to comment Share on other sites More sharing options...
Nic Posted August 3, 2011 Share Posted August 3, 2011 Facelift NA Supras were factory fitted with the V160/161 6spd box, although with different gear ratios to the TT, see HERE I'd stick with the 5spd box unless you can get hold of a 6spd box from an NA. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 3, 2011 Share Posted August 3, 2011 This is the main reason, but I was also hoping that it would make things a little better for the motorway. I was also curious to see if it was an easy enough job to do. The easiest and cheapest thing to do (as far as I know) would be to get your hands on a J-spec TT auto diff and fit it to your car with the 5 speed box. That'll drop your final drive from roughly 4.1 to 3.8 which in turn will drop your engine speed by about 8% for a given road speed & gear combination. The only drawback to that is your speedo will be out, on the slow side, probably by the same amount, so you'll need to be mindful of your indicated speed or just use GPS. Quote Link to comment Share on other sites More sharing options...
Guest Jamesmkiii Posted August 3, 2011 Share Posted August 3, 2011 My 1993 was a NA Auto Factory car. We put a v161 and 3.266 rear behind the NA motor before I did my TT swap. It was an excellent combination. The freeway cruising was around 2800rpm at 128kmh. But if you never plan to do a turbo swap then just find a different rear diff with a lower ratio. Quote Link to comment Share on other sites More sharing options...
Guest drummerboy08 Posted August 3, 2011 Share Posted August 3, 2011 Thanks guys, this kinda answers my question. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 3, 2011 Share Posted August 3, 2011 There is feck all difference between a 5 & 6 speed in that respect. The top ratios are nearly identical, the 6 speed is just a closer ratio box requiring an extra gear to get there. A final gear (diff) change is a far cheaper option for better motorway cruising. But acceleration will be sacrificed somewhat. If you are set on a 6 speed box a diff change will be required anyway. really the 5 speed i put in my N/A aerotop really feels like it needs another gear , is having an N/A auto diff going to make any difference ? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 4, 2011 Share Posted August 4, 2011 really the 5 speed i put in my N/A aerotop really feels like it needs another gear , is having an N/A auto diff going to make any difference ? No mate, the NA 5 speed and the NA auto have the same diff ratio, 4.083:1. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 4, 2011 Share Posted August 4, 2011 cool thats good to know at least i dont have to buy a new diff Quote Link to comment Share on other sites More sharing options...
Kirk Posted August 4, 2011 Share Posted August 4, 2011 My 1993 was a NA Auto Factory car. We put a v161 and 3.266 Where did you get the 3.266 rear end from ? Quote Link to comment Share on other sites More sharing options...
Guest Jamesmkiii Posted August 4, 2011 Share Posted August 4, 2011 (edited) Where did you get the 3.266 rear end from ? The 3.266 came with the V161 Swap. The whole swap came from a Jap Spec NA. It was ordered from Jdm Imports in the States. I would prefer a 3.133 myself just to drop the RPM's slightly lower Edited August 4, 2011 by Jamesmkiii (see edit history) Quote Link to comment Share on other sites More sharing options...
Kirk Posted August 4, 2011 Share Posted August 4, 2011 Surely though the car must of felt slow with such long gears? Quote Link to comment Share on other sites More sharing options...
Guest Jamesmkiii Posted August 4, 2011 Share Posted August 4, 2011 (edited) It did not feel slow because the V161 and 3.266 is from a NA car. So it felt like a normal 5-speed car with overdrive. My car is GTE Swapped now with a 6265 precision turbo around 500whp. The shorter V161 gears are excellent and it pulls very nice in the top end. No it feels like it could use the 3.133 from the USDM TT 6-speed cars. Edited August 4, 2011 by Jamesmkiii (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Jamesmkiii Posted August 4, 2011 Share Posted August 4, 2011 (edited) V160 Ratios: First gear: 3.827:1 Second gear: 2.360:1 Third gear: 1.685:1 Fourth gear: 1.312:1 Fifth gear: 1:1 Sixth gear: 0.793:1 V161 Ratios: First gear: 3.724:1 Second gear: 2.246:1 Third gear: 1.541:1 Fourth gear: 1.205:1 Fifth gear: 1:1 Sixth gear: 0.818:1 Edited August 4, 2011 by Jamesmkiii (see edit history) Quote Link to comment Share on other sites More sharing options...
dude Posted August 5, 2011 Share Posted August 5, 2011 really the 5 speed i put in my N/A aerotop really feels like it needs another gear , is having an N/A auto diff going to make any difference ? Try a J spec TT auto diff. Quote Link to comment Share on other sites More sharing options...
Noz Posted August 5, 2011 Share Posted August 5, 2011 how easy is the swap the diff's? id love to swap them out. Quote Link to comment Share on other sites More sharing options...
