Who is running traction control on their Syvecs ecu?
Chris Wilson
I removed the trac butterfly in my single 6 speed as the Syvecs doesn't use it.
I noticed with my throttle body that there is only one cable going to it which is obviously the throttle cable. should there be two with the traction butterfly connected?
Can I remove the trac pump and all the pipework right next to the abs system?
The second cable people have is for the stock cruise control :)
Ahh. Well thats something else that I didnt know :)
How do I know if the trac butterfly is connected? Is there a fuse I can check or pull out and see if the syvecs TC still works?
Just unplug them, from memory there are cables on either side, one side is a sensor the other is a stepper I think :D
