Radiator change - how much coolant required?
_Shane_
Alright guys,
I just bought a new thicker radiator for my mkiv supra tt and I will be putting the new rad in later
My question is how much coolant do i need, reason im asking this is because i roughly have 6 liters or toyota red for life coolant and if i put this in the system and say its not enough can i top the rad up with water ?
Thanks in advance
Shane
I use the red coolant but after dumping about 3 litres on the floor, it was replaced with some distilled bottled water and is fine, all it means is that it can't go as cold but as mine sits in the garage over winter, it won't drop to -15 in there.
Unless you have the car out in winter then I would say it's fine.
