Guest Rob Andrew Posted July 30, 2011 Share Posted July 30, 2011 (edited) Hi, Has anyone come across a fault when you start your supra it fires and run as normal but when you release the igition key it cuts out, I have discovered that the fuel pump looses its feed when the key is released, I understand that the cranking voltage supplies feed at that point, and when the key is released the alternator supplies feed via the EFI relay to the pump, before I rip it all out! just wondered if theirs a known solution. I have at the moment to get me around used a feed from the rear side lights to the pump via a inline fuse, so to start I turn the side lights on, or off to stop the engine. My car is a 1993 Supra N/A. Edited July 30, 2011 by Rob Andrew (see edit history) Quote Link to comment Share on other sites More sharing options...
