Josh Posted July 29, 2011 Share Posted July 29, 2011 On the way to Newquay doing 70 in 5th and if I put the accelerator down more than half way it was making a clicking sound that I could feel through the pedal then it started losing power. That stopped and then about 10 miles later the car was juddering and hesitating. Then it started losng power so I pulled into the services. On the way in it started making a loud knocking sound and was idling really rough. Any ideas and help would be appreciated as we need to get there. Thanks. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 Loud knocking from an engine usually means something fairly serious and probably terminal. Is there any oil in it ? water ? did it overheat ? wheres the loud knocking noise coming from, top or bottom end, more info req to be able to help Aren't you in the AA or RAC ? Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 It's knocking from the top of the engine and it's intermittent. There's enough oil and water in it. The temp gauge usually stays just into the "normal" part even on long drives. No loss of fluids or anything. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 My first guess would be a valve related problem What Fiesta is it ? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 29, 2011 Share Posted July 29, 2011 Is it pinking? Does it make the noise in other gears too at low revs, when you push the accelerator down most / all of the way? Is it a loud rattling sound? Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 My first guess would be a valve related problem What Fiesta is it ? Just noticed the oil and water and quite low but not that bad. It's a '96 P reg, 1.3. Going to top the oil and water up now and see if that does anything, but I doubt it. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 Just noticed the oil and water and quite low but not that bad. It's a '96 P reg, 1.3. Going to top the oil and water up now and see if that does anything, but I doubt it. How low was the oil ? was it on the dipstick ? Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 I started it back up and it makes the noise just idling. It's hesitating badly and the revs are dropping almost to the point of cutting out. The knocking noise is intermittent, not constant. Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 How low was the oil ? was it on the dipstick ? It was still on the dipstick. About 10mm up it. Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted July 29, 2011 Share Posted July 29, 2011 No help mate but sounds like you may need to get your walking boots on hope you have recovery sorry mate Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 (edited) Do you have any tools with you ? Can you get the rocker box off and check the tappet clearances, you might even have a broken rocker arm hence the top end noise and juddering inc losing power Which services are you at ? Edited July 29, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 Do you have any tools with you ? Can you get the rocker box off and check the tappet clearances, you might even have a broken rocker arm hence the top end noise and juddering inc losing power Which services are you at ? No tools Dunk. There's an AA guy sitting in his van here so I migrate go ask him. We're at Exeter Services. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 (edited) No tools Dunk. There's an AA guy sitting in his van here so I migrate go ask him. We're at Exeter Services. No tools !! your pretty much screwed then, Get your plastic out and go join the AA Check to see if the dizzy has come lose and screwed up the ignition timing Edited July 29, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 Just got a RAC guy to check and he's had a look and said one of the camshaft lobes has deformed or been damaged somehow and it's an engine-out job and probably over £500 to fix. The car only cost £800. No idea what to do as anything we do will cost a lot more than the car's value. Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted July 29, 2011 Share Posted July 29, 2011 ill take it ,its a 1.3 petrol , those engine are poo for eating cams, push rods and rockers . but the good thing is that engine was used right up to 2008 so there are loads on the second hand market , you get one for £100 . but that does not help you right now , just get off the motorway at least that way when it brakes down it will not cost you £150 to get tow'd off . Rich. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 (edited) ill take it ,its a 1.3 petrol , those engine are poo for eating cams, push rods and rockers . but the good thing is that engine was used right up to 2008 so there are loads on the second hand market , you get one for £100 . but that does not help you right now , just get off the motorway at least that way when it brakes down it will not cost you £150 to get tow'd off . Rich. Exeter services are off the motorway I'd try and get to where you were going then join the AA/RAC then call them when you are coming home Newquay is 90 ish miles from Exeter so good luck Edited July 29, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted July 29, 2011 Share Posted July 29, 2011 When he said services i assumed he was on the motorway . still not a good situation to be in . Rich. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 He is kind of but you actually get off the motoraway to get to the services, the end of the M5 is approx 5 miles away then its the A30 all the way Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 Right, the nearest garage will charge £40 to take the car to theirs then probably about £200 in labour just to have a look. Then there's the cost to fix it so maybe £450 in total, maybe more. I'm going scrap the car, then luckily as my Dad's in Bristol at the mo', he's going to pick us up and drive us to Newquay then I'll hire a car and drive back on Sunday. What a cock up!! Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 Car scrapped. £60 best price I could get until Monday. Go on holiday, end up with no car. Bad times. I need a friggin' beer!! Quote Link to comment Share on other sites More sharing options...
scotty71 Posted July 29, 2011 Share Posted July 29, 2011 (edited) haha how much fuel you put in 20 quid?? Car scrapped. £60 best price I could get until Monday. Go on holiday, end up with no car. Bad times. I need a friggin' beer!! why didnt you go in the Supra?? wont cost you much in fuel I wouldnt drive a "runner" that far!! thats what you bought, a daily driver to get you to work and back and to your boyfriends house not a 170 mile drive, that is the Supra's job Edited July 29, 2011 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
Spike3.0 Posted July 29, 2011 Share Posted July 29, 2011 Have a few mate! Quote Link to comment Share on other sites More sharing options...
Abz Posted July 29, 2011 Share Posted July 29, 2011 Car scrapped. £60 best price I could get until Monday. Go on holiday, end up with no car. Bad times. I need a friggin' beer!! You scrapped it within one day? You should have just brought a replacement engine! I am sure they sell for like £100 or so, then sell it on? You reclaimed the road tax dude? Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 29, 2011 Share Posted July 29, 2011 Car scrapped. £60 best price I could get until Monday. Quote Link to comment Share on other sites More sharing options...
Josh Posted July 29, 2011 Author Share Posted July 29, 2011 Didn't want to take the Supra as we're in a B&B and the parking's on the road. Plus there are a lot of drunken idiots about on the night so didn't want to have to worry about it. The car would have cost a few hundred to bring back, plus the cost of the holiday (had to leave £50 as a deposit). Altogether it worked out better to scrap it and get a lift down. It's only a cheap Fiesta. I'll pay a bit more for the next one! I did get the tax disc out too so I'll claim that back Monday. Now to carry on the drinking Quote Link to comment Share on other sites More sharing options...
