coza Posted July 27, 2011 Share Posted July 27, 2011 Hi got a big problem, My supra starts fine, also if i leave it for 1-15 hours it will still start but if i leave it for around 24 hours i cant start it battery drained !!! cant get my head around it local garage has checked the following alternator , any overchaging but need more time on it which is costing me lol , Has anybody had similar issues ??? My supra is a j-spec 3.0 N/A auto. any comments much appreciate it thanks.. Quote Link to comment Share on other sites More sharing options...
Scott Posted July 27, 2011 Share Posted July 27, 2011 You're battery isn't holding a charge. Change the battery..... job done. Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 27, 2011 Share Posted July 27, 2011 1) Take the battery out of the car 2) Fully charge it 3) Leave overnight 4) See if it's still fully charged. If the answer to 4 is "no", it's new battery time Quote Link to comment Share on other sites More sharing options...
Jimmy James Posted July 27, 2011 Share Posted July 27, 2011 Had a similar problem with a BMW 325 that I had. Kept putting new battery's in from halfords and always going dead after a couple days. Changed alternator, figured it was because my radio was wired wrong so it had constant power and everytime my phone rang in my apartment it would pick it up through the Bluetooth in the car and leave the radio on all night. Thus killing the new battery. Quote Link to comment Share on other sites More sharing options...
coza Posted July 27, 2011 Author Share Posted July 27, 2011 I have had changed the battery 2 weeks ago i thought it was that too ?? so i have got a good battery the alternator charges the car fine , its when its left for a day dont know what electrics could be checked, if i take the earth of the battery i can leave the car for days put it back on it starts ... really confused !! Quote Link to comment Share on other sites More sharing options...
Scott Posted July 27, 2011 Share Posted July 27, 2011 I have had changed the battery 2 weeks ago i thought it was that too ?? so i have got a good battery the alternator charges the car fine , its when its left for a day dont know what electrics could be checked, if i take the earth of the battery i can leave the car for days put it back on it starts ... really confused !! You're thinking about this issue all wrong bud. Unless really gubbed (shorted) the alternator won't have anything to do with your issue. When it doesn't charge... it doesn't automatically drain the battery. You are looking for a drain on the system. Has the problem been happening long? How long have you had the car? Have you had anything recently installed? Any audio equipment other than stock? You need to help us to help you, give as much information as you can Quote Link to comment Share on other sites More sharing options...
Havard Posted July 27, 2011 Share Posted July 27, 2011 Defo a drain somewhere..!! Quote Link to comment Share on other sites More sharing options...
coza Posted July 27, 2011 Author Share Posted July 27, 2011 okay mate i have had the car since may 27th so 2 months , i had put in a new cd player exchanged for the 1 left in , also i have had a cat 1 alarm installed but the problem was happening befor the alarm was insatlled, thats all i know havnt touched anything else, cheers, Quote Link to comment Share on other sites More sharing options...
Scott Posted July 27, 2011 Share Posted July 27, 2011 Surely the CD player installation has to be the fault then? Some stereo brands swap the +ive and the Ign+ wires, try switching the red and yellow wires at the back and see if the issue goes away. I had this issue years ago with my vectra, got the PC12 plug to keep the controls working and they were the wrong way around. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted July 27, 2011 Share Posted July 27, 2011 Your best bet is to check the current draw across the terminals with a multimeter, then pull fuses for different circuits until you find where the drain is coming from. Quote Link to comment Share on other sites More sharing options...
Scott Posted July 27, 2011 Share Posted July 27, 2011 Your best bet is to check the current draw across the terminals with a multimeter, then pull fuses for different circuits until you find where the drain is coming from. Draw...across the terminals? To check your current draw remove the terminal and stick the multimeter in between the earth cable and the battery terminal. Just don't start the car or anything like that or you will melt your meter and god knows what. 10A is the max for most wired meters. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted July 28, 2011 Share Posted July 28, 2011 Sorry I assumed people knew what I meant, not LITERALLY across the terminals! Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted July 28, 2011 Share Posted July 28, 2011 You shouldn't be drawing much more than 30ma. Mine's 22 with a tracker, an alarm, two inline immobilisers, gsm pager, and a carpc running in standby Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 28, 2011 Share Posted July 28, 2011 Disconnect the (charged up) battery and see if it starts OK the next day, if it does suspect a current drain. Suspects are alarms, door switches, or aftermarket gizmos. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted July 29, 2011 Share Posted July 29, 2011 If youve put in a sub with an amp you may have set it up wrong so the amp is always getting power. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted July 29, 2011 Share Posted July 29, 2011 I had this problem with mine ages ago and it turned out to be the amp. Another culprit on my old car was the bulb in the boot not switching off when the boot was closed, i dont think the Supra has a boot light though. I know you said the problem was there before you installed the Alarm, but how about before you installed the Head Unit. Pop the old HU back in for a couple of days and see if it fixes the problem. Quote Link to comment Share on other sites More sharing options...
coza Posted July 29, 2011 Author Share Posted July 29, 2011 i havent got a sub or an amp yet, need the drain solved first lol .. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted July 29, 2011 Share Posted July 29, 2011 I had this problem with mine ages ago and it turned out to be the amp. Another culprit on my old car was the bulb in the boot not switching off when the boot was closed, i dont think the Supra has a boot light though. I know you said the problem was there before you installed the Alarm, but how about before you installed the Head Unit. Pop the old HU back in for a couple of days and see if it fixes the problem. Mine does Quote Link to comment Share on other sites More sharing options...
